Blue Tooth Phone quality.--2 questions..Need HELP!!
2 questions:
1) When I connect my cell phone to the Blue Tooth where is the microphone on my 08 G37 coupe? Is it by the visor, dash..or where???
2) what should i do so people hear me better when im using the blue tooth? (besides yell). IS there any special settings I should be mindful of??
Thanks.
Thanks.
the microphone is by the rearview mirror. don't aim any vents up there and don't scream at the bluetooth. if you want to utilize the bluetooth better, hold down the bluetooth button for 10 seconds and it'll go into the speaker adaptation mode and it'll let you store 25 commands that you'll be using for better assurance.
I have a similar question regarding the quality of the reception for others. I have a BlackBerry connected and I can hear others very well. But almost everyone I speak to advises the sound is very poor and can barely hear me; I end up practically yelling.
During the winter, I had to turn off the heater to reduce all background noise which helped.
Is this a common complaint about the bluetooth quality?
For what it's worth, I use the bluetooth quite a bit and haven't had any complaints from people on the other end. They just say it sounds like I've got them "on speaker" which is true. But so far no complaints about me being difficult to understand.
You can set the outgoing volume in the on-screen menu if there is an issue with people hearing you well enough. Set it and then call a buddy to see if it sounds better. I have no issues with people hearing me clearly on my hookup with my Krazr.
2 questions:
Thanks.
Thanks.
Two, there is a volume control for outgoing (and incoming). Try adjusting that volume.
Cell phone have different versions of Blue Tooth; try another cell phone (if possible).
I used to hang my LG VX5400 from the driver's handle (near my left ear) and put it on speaker phone; it was much better than the G's Blue Tooth system. The Blackberry works fine.
Semper Fi
Kojack
Oct 9, 2015 05:53 PM
delfinparis
Oct 8, 2015 06:06 PM
butwhatuptho
Oct 4, 2015 07:51 PM
RexHavoc
Oct 2, 2015 11:47 AM
mikysee
Sep 28, 2015 11:18 AM
