Battery Capacity
Old Nov 3, 2008 | 08:26 PM
goredcar's Avatar
goredcar
Battery Capacity
I have a US car, and when I did an audio install this weekend I was a bit surprised how small the battery was. I suppose in most of the US you are not too worried about cold cranking amps... but even with the demands of a subwoofer amp, I wonder if this little battery will manage. On top of that -20 is not unheard of in the winter here. I am running a 600w RMS amp do you think I should get a higher capacity battery?
Old Nov 3, 2008 | 08:39 PM
nogoodname's Avatar
nogoodname
my new battery has a capacity of 1.21 Gigawatts
Old Nov 3, 2008 | 08:46 PM
goredcar's Avatar
goredcar
So... is this a replacement battery or the one that came in your G? I am assuming that you have a Canadian car...
Old Nov 3, 2008 | 08:50 PM
nogoodname's Avatar
nogoodname
lol, i'm teasing you, 1.21 giggawatts is nuts. that's "Back to the Future" crazy
and yea, I got a CDN G
Old Nov 3, 2008 | 08:56 PM
goredcar's Avatar
goredcar
Should have known... I have never seen a battery rated in watts before... and Giga is 10E9 which is huge. Anyway... have you looked at your battery under the lovely plastic cover? Mine is a lot smaller than the tray that it sits in... and while it may be OK for southern climates... I am a bit dubious about it up here.
Old Nov 3, 2008 | 08:59 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Probably wouldn't hurt to put an Optima in there.
Old Nov 3, 2008 | 09:01 PM
nogoodname's Avatar
nogoodname
mines regular size, it's just like Black betty's pics in the grounding wire thread
definitely not, it wouldnt hurt
Old Nov 4, 2008 | 01:02 AM
aznutx's Avatar
aznutx
i apparently killed my factory battery by using the seat warmer once...
it was fine until the day i used it then it died. dealer replaced for free
haha and i dont have any aftermarket audio equipment either. not yet anyways still working on it
Old Nov 4, 2008 | 01:09 AM
goredcar's Avatar
goredcar
I don't imagine that the seat warmer is light drain, but it would be nothing like a 600W amp that will pull in the vicinity of 50 amps on full load. I guess that I will be dropping in a big battery before winter...
Old Nov 4, 2008 | 01:31 AM
CrackHeadMonsta's Avatar
CrackHeadMonsta
Stinger batteries!!!!
Power² Series 1500Amp Battery
3100+ MAX Amps
1500 Amps 5 Second Burst Power
Only 2.5mOhms = Ultra Fast Power Response
68Ah Rating
Sealed Design Can Be Mounted In Any Position
Both Top and Side Posts
Mounting Tabs for Factory Locations
2 Year Replacement Warranty
You'll need more than 2 Optima's for just one of these.
Old Nov 4, 2008 | 02:25 AM
goredcar's Avatar
goredcar
3100+ MAX Amps
68Ah Rating
There is a brand marketed up here called "yellow tops"...often used in extreme audio applications... I wonder if it is similar to the battery you describe.
Old Nov 4, 2008 | 08:58 AM
DiamondGCoupe
Yellow tops are Optima's but there are many similar batteries. I used to run two 12" W6s on a 1400.1 with the stock battery. It lasted over 3 years and is still going. I do live in South Florida so it was only below 50 two days a year. You can see the light dimming slightly especially when you first begin driving but as long as you're not consistently driving 2-3 and turning off the car, it will stay charged. Maybe invest in a cap, I'm sure the battery can handle cold whether and even though the AMP is 600W unless you have a W7 or something comparable, it not using more than 300, or so.
Old Nov 4, 2008 | 11:11 AM
goredcar's Avatar
goredcar
Thanks for the info DiamondG... I am running an Alpine Type R (500w RMS), which is not in the same league as the W7 but probably close to the W6. I don't know much about JL so my comparison may be off, but my guess is that the W7 is similar to the Alpine type X (1000w).
Still, even with the type R, I can feel my hair move and all the mirrors are vibrating I am pretty happy with it especially considering the small, non ported enclosure.
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
TVPostSound
Sep 2, 2015 04:09 PM
