DIY: Door Panel Removal
Old Oct 2, 2008 | 10:39 AM
ironchef2008's Avatar
ironchef2008
  1. Remove cover inside door panel. Remove (1) 10mm bolt
  2. Remove door handle trim panel by pulling gently at bottom edge. Remove (2) 10mm bolts
  3. Remove light by prying gently at side. Unplug harness.
  4. Remove door panel by pulling gently at lower edge to rear of vehicle.
  5. Unplug (2) harnesses from power window switch, (1) harness from mid-woofer, and both cables from door handle assembly. Set entire door panel aside.
Attached Thumbnails DIY: Door Panel Removal-g37door1.jpg   DIY: Door Panel Removal-g37door3.jpg   DIY: Door Panel Removal-g37door2.jpg
Old Oct 2, 2008 | 10:44 AM
ironchef2008
After Removal Look
Here's what you'll see after panel removal.
Attached Thumbnails DIY: Door Panel Removal-g37door4.jpg
Old Oct 2, 2008 | 10:52 AM
ironchef2008
Tweeter Removal
  1. Remove (1) 10mm bolt. Carefully pry side facing front of vehicle and then slide entire panel towards rear of vehicle.
Attached Thumbnails DIY: Door Panel Removal-g37door5.jpg
Old Oct 2, 2008 | 11:27 AM
ironchef2008
Bose Speaker and Wiring Information
  • DS Woofer Positive:Red
  • DS Woofer Negative: Green
  • PS Woofer Positive:Green
  • PS Woofer Negative: Red
  • DS Mid Positive: Grey
  • DS Mid Negative: White
  • PS Mid Positive: Blue
  • PS Mid Negative: White
  • DS Tweeter Positive: Black/White Stripe
  • DS Tweeter Negative: Black
  • PS Tweeter Positive: Black/Red Stripe
  • PS Tweeter Negative: Black
**The tweeter does not have it's own dedicated wiring from the Bose amp. It is run parallel off the mid at the door harness.
**The wiring at the Bose amp is different the ones at the door. This is typical Nissan. The wires pass through two harnesses between the amp and speakers and the colors of the wires often change. For instance, the service manual shows the DS door woofer output on Bose systems without Nav as black for positive and white for negative. Yet at the door it's red and green. Always test each speaker for proper polarity to confirm proper wiring color as your car may differ.
Old Jan 31, 2009 | 07:35 PM
nmwstunna's Avatar
nmwstunna
I can see a pic of the back of the door panel. I want know how to take off the alum washi piece.
THanks
N
Old Mar 19, 2010 | 02:56 AM
Philip's Avatar
Philip
ya i have done it i adopted your method and got the results thanx
Old Mar 21, 2010 | 09:11 PM
pauliewalnutzz's Avatar
pauliewalnutzz
good diy
Old Jan 12, 2011 | 04:38 AM
theknight's Avatar
theknight
thanks for the post... like it
andrewk523
Nov 11, 2015 05:49 PM
Murkr
Sep 28, 2015 10:45 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
JerseyG
Sep 23, 2015 02:20 AM
