Installing Amp and Subs in G37
In a bit i am doing a Installing for a G37, i plan on taking alot of pics for everyone to see every step. So i got a pretty clear idea of what to do i am posting this to make sure i got this right. If all comes out right and correct i will post a detailed guide for all noobs to want to know how to do the install.
System:
My plan is to splice into the B43 Woofer Amp Connector which is in the trunk area.
SO!
System:
- JL Audio A1400
- JL Audio 12W3v3-4
- JL Audio RBC-1
- 4 gauge Power Wire
- Remote Wire
- RCA Wire(Red and White phono)
- Some Hook up wire
SO!
- Remote Wire -----> Terminal #3 on B43
- RCA White Negative ---> Terminal #9 on B43
- RCA Red Negative ---> Terminal #9 on B43
- RCA White Positive ---> Terminal #8 on B43
- RCA Red Positive ---> Terminal #8 on B43
well i pay the local installer in my town make a custom box for that two thin sub... it look not bad rigth ? he is the best installion guy that list in the top 100 installer in USA..if u want to see all the shape i can post more
System:
SO!
System:
- JL Audio A1400
- JL Audio 12W3v3-4
- JL Audio RBC-1
- Remote Wire
- Some Hook up wire
SO!
The signal from the HU is a blanaced signal. You will need to either have amps that take in a balanced signal or you will need a balanced to unbalanced converter, not a Hi-Lo converter. If you just try to tap into the + and - signals with RCA's you will get bad noise.
+1 yw dilyo hehehe jk
i appreciate this thread listing. Im anxious to see the outcome and any potential difficulties you may encounter along the way...
Im about to start an install myself in about 2 weeks.
Currently in the process of accumulating my components
which are:
JL 500/1 for 4080 custom box with Polk SR 104 sub (per Ainslie recommendation)
JL 300/4 for Infinity Kappa 3 ways in rear deck(positional tweets/mids)
and
Infinity 4" coax 2 way(positional) for rear seat side walls
JL 300/2 for JL ZR series 6 1/2" components for front door
hope this is a decent arrangement...any advice or suggestions is appreciated..
ryan
which are:
and
ryan
