MP3 ID3 Tag Support
MP3 ID3 Tag Support
Does the Bose Premium Sound system support MP3 ID3 tags for MP3 cd's played through the disc changer? I burned a cd with several folders and see my folder names, but the songs only show up in the list as the file name as opposed to the id3 tags. Any way I can change this or is this all the system supports?
Thanks
Thanks
Found the answer to my own question. The sound system does recognize id3 tags, but it only displays the tag when the text option on the screen is selected. When traversing through folders you can only select songs via the actual file name.
So if you name all of your files in the format I do, your screwed unless you know what track # your looking for.
The format I use is: track # - Artist - Song Name.mp3
So essetially it could be: 05 - Senses Fail - Calling All Cars.mp3 which is too long of a file name that only a portion of the file name will display.
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
4DRZ
Drivetrain
34
Aug 5, 2021 10:02 AM
delfinparis
Oct 8, 2015 06:06 PM
