Ip Audio Build
Old May 10, 2008 | 07:05 PM
Lou@Amplified's Avatar
Lou@Amplified
Ip Audio Build
Image Dynamics IDQV3 10 inch subs, Q 750.2 amps, XS69 components. Stinger xpert cables and fuse block
Old May 10, 2008 | 07:12 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Free Air subs.... interesting
Old May 10, 2008 | 07:28 PM
Lou@Amplified
YES very.. and it works and trunk space is still there
Old May 10, 2008 | 08:00 PM
xeddyboi420x's Avatar
xeddyboi420x
Clean
Old May 10, 2008 | 08:11 PM
The1andOnly's Avatar
The1andOnly
This set-up is super clean. I've seen Lou's in person, and I gotta admit, i'm not that big of a sound guy, but this set-up was enough to make me consider getting it done.
If any of you socal guys are considering upgrading the audio but are worried about trunk space, forget the sub-box on the side and go with this set-up.
Old May 10, 2008 | 09:10 PM
dillyyo's Avatar
dillyyo
Did you cut out the back of the door panel to fit the 3" midrange? I only assume this because I was under the impression that the stock speaker fit within a closed cup like closure of the door panel. Am I misinformed?
Old May 10, 2008 | 09:18 PM
IP37's Avatar
IP37
looks ok i guess
Old May 10, 2008 | 09:59 PM
bboysteele's Avatar
bboysteele
How does it sound with your back seats up? Or did you take the back of the seats out?
Old May 10, 2008 | 10:30 PM
Lou@Amplified
its sounds good with the seats up. they sound a little better when they are folded down
Back seats are still there
Old May 10, 2008 | 10:35 PM
Lou@Amplified
this set up is with Image Dyanamics xs69s and what i installed on there is tweeter. You can either hot glue a 3.5 midrange or make a bracket for it to fit. Also, another option is to cut it.
Old May 10, 2008 | 11:03 PM
J.Oh's Avatar
J.Oh
what did this set up cost
Old May 10, 2008 | 11:08 PM
Lou@Amplified
about $2500 for the components(2 subs, 2 amps and set of components with 6x9 mid bass. All Image Dynamics. I don't know what others would charge for the install.
Old May 10, 2008 | 11:20 PM
armen818's Avatar
armen818
all i have to say is
that is a beautiful setup, i like a IB setup in a G37
how did you seal the front from the rear area??
these IDQ's??
thats what i want, but with a single 12inch IDMAX
nice job it looks great
BTW. can you get couple of pix under the rear deck,
i wanna see how much room is there, from the sub to the top of the rear deck
Old May 10, 2008 | 11:42 PM
Lou@Amplified
these IDQ's??
I can't take anymore pics, this was one of our customers cars. I will take some when mine is done. Its pretty much the same set up but my amp rack will be different since im using Zapco amps. My front stage (doors) im using Morel Elate 9's .3 way is super clean.
As for the 12, it won't fit with this set up. You might have to make a baffle board that further into the trunk. I also would not recommend the IDMAX if your thinking IB. I would look into the IDQV3 12'S that was just introduced. If your set up is for SQL, the IDQV3 is plenty. If you need help with your setup, let me know. I will be working with Matt and Eric at Image Dynamics on other IB projects for our other cars.
ID ALL THE WAY
Old May 10, 2008 | 11:58 PM
armen818's Avatar
armen818
thats going to be a nice setup for your car. the reason i wanna go with the IDMAX and IB is that ive heard couple of them and i liked it, the SQ was very good. if you have a shop i would love to come by a listed to couple of the cars.
