Stash for the Intel Key
Excellent, I'm convinced and I'm quite happy about it. Having that warning makes sense.
Does anyone have a link to this PDF file? Or do I have to pay for it, or are links to it not allowed?
___________________
G37S all options except 4was...
___________________
PDF file
http://www.g37-tech.com/wiki/Categor...Service_Manual
Service and Owner Manual are on this site page.
Just as a Note... BMW's do charge the keys to the car and store service info on the key. If you take your car in the service advisors have a little reader that the key sits in that will let them know all the pertinent information about the care and all the warnings and service issues.
They always reminded me to rotate keys ever once in a while to make sure that the spare key did not die.
No that spot should only be used when you're in your car. DON'T Leave your key in there when you are not in your car. That spot is also used when your intelligent key loses its battery and your car cannot tell you have the intelligent key. You put your key in that slot and it lets you start the car.
Well, that was part of the design as I am pretty sure its stated in the manual as a function of it. Also, usually valeted cars are in a controlled lot and if not, I am sure they would take the key away, as has been done with me.
What are you talking about? It has nothing to do with valet or anything. The key stash is used to put your key in if you want but you don't need to. If the battery dies on your key then you will need to put the fob in the key stash to start the car. A valet just needs your key fob with the key for the glove box and door removed from it to start the car but the key fob does not need to be in the key stash at least not when I tried it.
philttz
Feb 17, 2016 11:26 AM
FlyIce
Sep 29, 2015 04:07 AM
AMai1215
Sep 13, 2015 12:59 PM
