Hard Drive Mod
Old May 2, 2022 | 11:35 AM
  #346
BULL's Avatar
BULL
Moderador
Originally Posted by thescreensavers
What part of S.FL? I was going to play around with taking apart a JY head unit before mine looks like it's $80 from Upullandpay.
Ft lauderdale.
It really all depends on what's all needed.
I own a 2010 so I'm down to experiment on my own however for testing purposes I take:
  1. 2010 M&A + wiring
  2. 2010 Navi switches
  3. 2010 A/C + radio controls + wiring
Many times especially at places like LKQ/Upull will give you cheaper prices is you remove the warranty (included in pricing)
For those who own 2010+ looks like SSD HD and programming?
Old May 2, 2022 | 11:54 AM
  #347
iCrap's Avatar
iCrap
The full test setup would be:
Head unit
Radio / climate buttons
Buttons / **** under screen
LCD
GVIF cable (?)
Then for getting serial access you need arduino, level shifter, breadboard, some jumper wires and resistors.
I have a full 07-09 bench setup which is what I've been using. I just ordered a 2010 screen. I need a 2010 head unit.
I actually don't know if the buttons are different from the two systems. I would think probably not.
Old May 3, 2022 | 08:27 AM
  #348
BULL's Avatar
BULL
Moderador
I think I'll stick with locating the parts.
I have 7 engine harnesses, 1 VQ37VHR with exhaust on a stand, 6 swap harnesses in the garage.
I'm going to wait a bit until I start getting into Arduino.
Old May 3, 2022 | 08:17 PM
  #349
iCrap's Avatar
iCrap
I grabbed myself a 2010+ nav unit and screen off eBay. Gonna play with it. If I get unlocked maybe one of you 2010+ guys can test it in your cars.
Old May 4, 2022 | 10:26 AM
  #350
ILM-NC G37S's Avatar
ILM-NC G37S
If my existing unit gets any slower I might have to be one of those guinea pigs...
FWIW, thank you for your persistence, time, and work on this project. You've made more headway than most!
Old May 4, 2022 | 10:41 AM
  #351
BULL's Avatar
BULL
Moderador
I'm down for testing.
Old May 4, 2022 | 10:53 AM
  #352
rotarymike's Avatar
rotarymike
Moderator in Moderation
I might be up for that, as I was considering using the PI replacement that ICrap did (in case something gets borked).
Old May 7, 2022 | 12:37 AM
  #353
iCrap's Avatar
iCrap
This function button thing has really got me stumped. Can't figure out how to map it. We know it's possible and at least 2 people have done it. (youtube guy and murano guy)
Based on this video it's possible to map it to the 6 (?) radio hotkey
Maybe its not possible on my 09 headunit? the newer one is still on it's way. I dunno, I'm stuck.
Doubt those guys would be willing to share any info with us
I attached the app.bin from the GT-R if anyone wants to poke around.
This is the list of console commands I have already extracted. (GTR 2010)
btm vdb mgrnet teld tels htl rcv mdp tms map trfe trfs trf rpf aps loc as **** se ss rif rgdj rgd gid hdlmfd mfd imdrive imcarinfo imcost imrange immeter immainte imcnct imdenso imwar dspset vm hmg hev dm menu hmists hottime dmlastck dmrtn dmmng dmbuf dmnow onmap lang res hms hdlm hdltmcmes hdltmcair hdltmcsend hdltmc cap adpbtd svr cddb xau spd sig obj xgl font xmcu hdctl dusa dus mgrweb xrudac dsp cfd hdd clw sns dspst dspsd mtrif mtrsd tcp tce tc xrpo xrvt xrsn xrf xfver xrde xrspn xrmfc xrd xrsfl xrccs xrcc xrscs xrsc xrmc xrpc iollist iodev candiag pdictmu iolring mcan docan mgrbt pmgradc pmgrspd ldset dlp xste xsts xsrad xcpl xplsd xgrad xgpsd xclw xgte xgts xtp pmgrgps ioltimer ioltime iomsgio iomsgi atv ioctl fds devs drvs iodspi pldck iodpt lte lt bpss bpb bps bpc bpa bpp bp ls rm pld call swm pmgrestab pmgrecho pdicscif pdicusart pdichspi pdicml9620 pdichcan mgrmcan acm PUD_PromInit fcopy mqsa mqs cs exc exd ex ms d m spyStop spy dbgHelp tt e mRegs l ti so s cret c bdall bd b xcv sca sc prc ee es pw oss sas sd promd proms cf co osee oses tshow tr ts ver i
Here are the console commands from the 2014 q60 drive
btm bcsp xrbt xroem lpavm cwsh cws teld gpshist snr tms xrinit gid dsh hdlxmw hmixmw hvac pmgrdiagn pmgrcamera mgrvcan candiag mgrcan hdlmtr hdltmcair hdltmcsend hdltmc trfe trfs hif refdbg rdset rprt rdbg ipverr navistsreset navistsset ipvreset ipvset self hdlmfd mfd xrdnk aview hmi avm sdl xrcnf xmcu ir xgc1 verall imng wel sql mdc mal xrnt lang dat hdlm atv devs drvs fds oms ldset dor vm onmap trf map rcv vdb aps as **** se ss etcs camera switch rgdv rpf dspctl tol rif hwn rgd rgdc hdm dspset imtest usbrb tel mum vfi lvc hms menu mtrif mtrsd tcp tce tc clw sns xrpo tla hnw dsp obj svr usbmgr hdd ucm acl mgrweb mgrweb adpbtd adp gdicscpu pdicusart sys disc aux dvd audio mec bpss dusa dus ls rm xtp xgpsd xclw xgte xgts xcpl xste xsts xsrad xrsn xrf xfver xrde xrspn xrmfc xrd xrsfl xrmc xrpc cap mgl font xgl mgrbt pmgrestab echo dlp xplsd xgrad iodspi pldck lte lt bpb bps bpc bpa bpp bp pld wdd fcopy call swm mgrmcan acm iodpt iomsgio pmgrspd pmgrgps dspst dspsd pmgradc pdictmu pdicspd pdicscif pdichcan pdicadc i2c iomsgi mcan docan ioltimer ioltime iolring iollist iodev mqsa mqs cs exc exd ex ms d m spyStop spy dbgHelp tt e mRegs l ti so s cret c bdall bd b xcv sca sc prc pw ee es ver oss sas sd promd proms cf co osee oses tshow tr ts i
File Type: zip
Old May 7, 2022 | 12:09 PM
  #354
AdamBritt's Avatar
AdamBritt
I wonder if there is something in the commands where the unit reads whatever input from the function button as a certain value that you can change it to look for the value from the 6 button. Would be nice if that was in an ini or some kind of file instead of baked into the hardware code.
Old May 7, 2022 | 12:20 PM
  #355
ILM-NC G37S
I can't speak for Murano guy, but for the FX35 guy (presses '5' button to activate) I believe he is using some type of module to add both the GT-R menus/ functions, as well as the other things he has added. If you notice, when he starts the car, a separate display dialog comes up BEFORE the standard splash screen...
If we knew the resistor value for the GT-R's function button...
Old May 7, 2022 | 12:52 PM
  #356
iCrap's Avatar
iCrap
Aw man, i just realized that. I think you're right, he has some other module hooked up which is probably sitting on the CAN waiting for the 5 button and sending the function button.
I mean worst case I can buy a GT-R panel off eBay. That's an expensive thing to do though.
Well, here is a partially busted one.
https://www.ebay.com/itm/12474543597...torefresh=true
Old May 7, 2022 | 01:02 PM
  #357
ILM-NC G37S
With all due respect, even broken it is not worth $120. The GT-R tax is absurd on these parts.
While having this added functionality would be ideal, if it could be accessed on the software side then great. But to invest a ton of money- even as a hobby- at some point it is just not worth it.
Be interesting to see if the gadget from "motorvate" would interact with this...
Old May 7, 2022 | 02:02 PM
  #358
ihateu3's Avatar
ihateu3
I mean worst case I can buy a GT-R panel off eBay and read the values. That's an expensive thing to do though.
If you head over to the GT-R forums and post on one of the Tesla style screen swap threads (T-Rex), or make a post looking for this part, I think you could get it fairly cheaply or close to free since this part is discarded when installing those screens. Might even try calling the shop houston, or other shops that install these screens to see if they have this part laying around left over.
Old May 7, 2022 | 02:54 PM
  #359
iCrap's Avatar
iCrap
I offered the guy much less on the broken one, maybe he will take it. it seems like scrap otherwise. I agree to invest a bunch of money is not worth it.
Good point on the GT-R forums. i'll make an account and ask. which is the most active GT-R forum? I see like 4 of them.
Old May 7, 2022 | 03:06 PM
  #360
ihateu3's Avatar
ihateu3
I think gtrlife is the most active.
