Hard Drive Mod
dont need old computer just usb ide adapter and https://software.compuclinic.de/tosh...chaften_en.php
Plus, for those reading- don't bother with the "demo" version. It does absolutely nothing. Also, several searches have not yielded any "unlocked" versions of the software.
Seriously, thank you for the lead, but I'm too cheap for that frivolity.
I enjoyed going through the Egrand files you posted earlier.
Some of the RCL files had over 4,000 images used for the display.
In looking for text in the BIN files, there were some interesting items:
"CAN ID0x%03x:0x%02x
20 | | tx log enable
21 | | tx log disable
30 | | err log enable
31 | "
and
"../SI/08/X2J9/SOFT/APP0032/AUDIO/PLAYER/USBAUDIO/SRC/acl_usbaudioplay.c"
Well, interesting to me, but not really useful
Since Ghidra supports the SH series of processors, I might try to look at the disassembled code and maybe something will stand out.
bin files is don have text is like archive with all files or program is combile by VXWORKS/QNX System
Wind River Linux distribution i think is be easy to open that very difficul to find that linux
YES, please post a link to it.
31 | "
and
31 | "
and
uh sort of, if you look at the diagram there are multiple inputs for power, ground and ACC. i think there's like 6 of them, same with grounds.
btw, is there a writeup for unlocking the drive and mounting it?
I must have a dud head unit then... I get the Infiniti splash screen then it just... stops...
This thread pretty much explains the unlocking procedure. You do know the HDD has to be removed from the headunit first? My plan is/was to unlock the HDD and clone it to a SSD. Eventually.
Then, after the HDD is unlocked, this thread will explain how to mount the HDD/headunit and access the programming/feature lists.
Yeah I already removed the drive. I found an old PC with IDE in my pile of stuff, and even an IDE USB enclosure so i'll see if i can do anything with it.
btw, i tried booting with no HDD and I only get a splash screen as well. maybe your HDD is a dud?
