Sponsored By:
Sponsored By:
g37x coupe maintenance?
Old 08-16-2015, 10:17 PM
timc00k
timc00k's Avatar
Hi guys,
I got my 2011 G37x coupe in April with 22,250K miles. Currently it has 25K miles. I see there is a sticker on the windshield for service at 25,300K miles.
What sort of maintenance should I do?
Oil change? (I'm guessing premium?)
Tire rotation?
Clean filters? (are there any better filters available than stock?)
Old 08-16-2015, 11:07 PM
dbeachy1
dbeachy1's Avatar
It's likely for an oil change given that there's a window sticker for it. Do you know when the oil was last changed and what type of oil it is? If it's synthetic it should last at least 5000 miles.
Old 08-17-2015, 08:02 AM
Received 4,941 Likes on 4,174 Posts
Did your G have the full owners manual & maintenance log book in the trunk? If so, hopefully previous owner kept track of the services done. Also if it was serviced at an Infiniti dealer they should be able to look up any service based on your VIN (AFAIK).
If you can't find any specific service work records then oil/filter, tire rotation, and check your brake pad wear. Also the service reminders on the gauge cluster (behind the steering wheel) can tell you the intervals the previous owner was going with, or at the very least you can reset them to the intervals that you want to follow in the future.
Old 08-18-2015, 03:41 PM
timc00k
timc00k's Avatar
I honestly have no idea when was the last time oil was changed and the type of oil it was.
Is it required of synthetic oil change for Infiniti vehicles? Is there anything better than synthetic?
Thanks.
I did check the service reminders on the gauge and I'm almost about to reach the threshold. I have not received any alerts yet but the screen shows I'm very close to it.
Old 08-18-2015, 04:59 PM
If you have no idea about the oil I'd change it ASAP w/ full synthetic, brand is up to you. I've had good oil analysis using Pennzoil Platinum. I also use the bigger V8 Infiniti filters, the V6 filters are dinky. I use a 2012 Infinti M56 to get the proper filter part #.
Some swear by the Nissan Ester oil, but you'll get excellent results w/ full synthetic from the major brands.
If you do go w/ full synthetic you can go 6-7,000 miles between changes. I go 6k miles.
If you plan to stick w/ changing oil every 3,000 miles regular non-synthetic oil is fine.
Old 08-18-2015, 07:04 PM
JSolo
Just say no!!!!!
JSolo's Avatar
If you plan on keeping the car a long time, I'd consider doing a full fluid refresh.
- engine oil
- trans oil
- transfer case oil
- rear differential oil
- brake fluid flush
- coolant drain/fill
- inspect belt, replace if starting to crack
- replace all filters (2x engine and 1x cabin air).
- power steering fluid
Practically all of these are DYI if you're mechanically inclined. If not, expect to pay $$$ a shop to do it. Some of these services may not be needed, but better to be proactive with respect to maintenance than reactive.
Old 08-27-2015, 01:37 PM
timc00k
timc00k's Avatar
Are there any "good" quality filters for the engine/cabin air? Are all filters the same?
I would assume they do the same job, right?
Old 08-27-2015, 09:38 PM
I've been using Bosch Premium oil filters and I use the ones for the Infiniti V8s, it's quite a bit bigger than the dinky 6cyl filters and still fits under the plastic splash pan.
For cabin filters most should suffice although I'd get the ones w/ carbon.
Old 08-27-2015, 09:50 PM
Landshark
Landshark's Avatar
i would guess the dealer would bend you over for one. buy them at Walmart.
Old 08-27-2015, 10:37 PM
canucklehead
canucklehead's Avatar
Wix makes high quality filters for both applications. Rockauto.com has great pricing. I usually stock up enough to last a few years.
Old 09-05-2015, 05:12 PM
cconklin2
cconklin2's Avatar
i use rockauto whenever possible. good prices, fast service..
G37xhibeet
11-15-2016 09:29 AM
JoshB
10-15-2015 03:08 PM
drkashifa
08-18-2015 04:38 PM
cellwoot
08-13-2015 04:27 PM
Spicy_Kimchee
08-11-2015 09:10 AM
Quick Reply: g37x coupe maintenance?
