DIY: Sedan interior and exterior LED bulb installation guide
Old 06-27-2011, 11:19 PM
AZg37
AZg37's Avatar
I installed LED bulb replacements on all my interior lights as well as my license plate, trunk, and reverse lights. The following are instructions and bulb guide for a 2009 G37 sedan.
All lights were purchased from iJDMtoy.com
Bulb Information:
Links to what I purchased:
map lights, door courtesy lights, and rear reading lights package:
2007-2011 Infiniti G35 G37 6 Lights Direct Fit LED Interior Lights
Vanity Mirror Lights:
TS-14V1CP F30-WHP Fuse Type 6614F LED Bulbs | LED Vanity Mirror Lights
Trunk lights and license plate lights:
5-SMD T10 168 194 LED Bulbs, Car Interior Lights, License Plate Lights
Reverse Lights:
13-SMD 5050 T10 Car Automobile LED Light Bulbs 168 194 921 2825
If you want to pick your own bulbs, the sizes are:
Map lights = 194
door courtesy lights = 194
rear reading lights = 194
vanity mirror lights = 29mm
glove box = 57
trunk = 194
license plate light = 921
reverse lights = 921
All you need for installation is a small flat head screw driver to pop the plastic covers off all the factory lights. When you are replacing the bulbs, be sure and test every new LED bulb and make sure they work, you might need to turn them around.
Map Light install:
Pop one side of the cover off, then put your finger inside and push straight down and pop the back side off.
pull out old bulb:
replace the bulb with the LED bulb and enjoy the new bright light!
Vanity Mirror lights, follow same basic steps as above:
Door courtesy lights:
The housing will pop out, you need to unplug it and use the screw driver to pop the outside cover off and expose bulb.
Rear Reading Lights:
The trunk light is enclosed in a plastic housing that you snap open:
The reverse lights require you to remove the trunk lid cover by removing all the snaps and handle.
Twist the bulbs and they pop out:
License Plate lights:
These lights have a clip on the side that will release the bulb housing:
Finished Product:
The following 3 users liked this post by AZg37:
hammonds42 (06-07-2014), STownSaint (03-22-2017), Vizard_87 (03-09-2015)
Old 06-27-2011, 11:55 PM
LexiG37
LexiG37's Avatar
Nice write-up, thanks!
Old 06-28-2011, 11:08 AM
Djfarhan
Djfarhan's Avatar
thanks for the DIY!
Old 07-06-2011, 12:51 PM
kerr37xs
kerr37xs's Avatar
great DIY
do you after pictures of the reverse lights?
Old 08-13-2011, 04:13 AM
tony_m_777
tony_m_777's Avatar
how much brighter are the new reverse lights vs stock?
Old 08-17-2011, 04:49 PM
1cleanG
NextLevel Performance
1cleanG's Avatar
nice writeup man, I just ordered the interior lighting kit from IJDMTOY and was wondering if there was anything special to pop the interoir bulb covers off, guess not?
Glad I looked at this.
Old 10-06-2011, 04:49 PM
Alpha Ice
Minnesota G owners
Alpha Ice's Avatar
I love IJDMTOY, I've never had an issue with any of their LEDs yet! Great quality and fast service!!! I was almost going to go with the large LED panels like this but I thought it might be too bright. I'm glad it turned out well tho
Old 10-06-2011, 11:07 PM
the dreame
the dreame's Avatar
Thanks a lot
Old 06-28-2012, 01:45 AM
xref
xref's Avatar
Thank you!
Old 07-02-2012, 10:19 PM
thisGuy714
thisGuy714's Avatar
Awesome! I just ordered my kit and this DIY will really help. Thank you!
Old 11-19-2012, 05:32 PM
dj arsonist
dj arsonist's Avatar
For the Door courtesy lights, how do you get the bulb out? I can't pull it out. It seems that both are really jammed in.
Old 02-23-2013, 04:10 PM
Rikter
Rikter's Avatar
Did a search and found this old threat.. instead of making a new one I hope someone can answer this question. I have a '08 coupe and I'm looking to take off the dome light covers to replace with LED. Do the covers(the piece you push on to turn the lights on) just pop off with a flat-head screw driver like the sedan or is there more to it than that? I'm worried about denting the plastic surround when using the screw driver as a lever.
Old 02-24-2013, 04:52 AM
quakerroatmeal
quakerroatmeal's Avatar
It pops off with a flat head. You could wrap the flat head in black tape to help the surrounding. I used my finger on the opposite side to use it to press against instead of the plastic piece.
Old 02-24-2013, 09:37 PM
Rikter
Rikter's Avatar
Thanks for the reply. I will try again tomorrow when there is more daylight.
Old 05-20-2013, 12:26 AM
STownSaint
STownSaint's Avatar
Are the bulb types/sizes list valid for a 2013 sedan as well? (TIA)
Quick Reply: DIY: Sedan interior and exterior LED bulb installation guide
