Is 18x10.5 with 5mm offset too much?
Old Dec 29, 2019 | 06:30 AM
CallMeCrop's Avatar
CallMeCrop
Hello everyone, im fairly new to this. I have a 2011 g37s coupe and Ive been looking to get a new set of wheels soon. I came across a set that i think would look killer and it seems no one has any pictures of them on a g37 so i may be the first to do so. The specs of the rear wheels would be 18x10.5 with 5mm offset.. Now that sounds incredibly aggressive in terms of offset to me, and i dont mind rolling fenders if i have to but would that even fit in the first place? If they dont fit i will end up going with a 9.5 wide with 15mm offset as im fairly sure that would fit.
Old Dec 31, 2019 | 10:32 AM
jdog78's Avatar
jdog78
Hi CallMeCrop, the short answer is no and this is the wrong forum for this. You can find your answer in the URL below.
https://www.myg37.com/forums/brakes-...7-coupe-2.html
In addition, you can play around with the offset with one of the online calculators. My favorite is https://www.willtheyfit.com/
If you start playing around your chamber and etc. That's a realm I didn't cross. Good luck on your wheel quest!
Old Jan 2, 2020 | 07:47 PM
bPChaos's Avatar
bPChaos
This is an 18x10.5+30 and 275/40R18 with mostly factory camber, and rolled/pulled front fenders. You can judge if that will poke too much for you.
BigBadWolfe
Mar 7, 2017 01:11 PM
ben_ben125
Jan 23, 2010 02:39 PM
Graham
Oct 27, 2008 06:18 PM
Jkg37
Jul 17, 2008 08:56 PM
