Help Enkei RPF1 TPMS,, does OEM work?
Old Jun 29, 2019 | 05:02 PM
mark.dtom's Avatar
mark.dtom
Hey all. I’ve had an account for a little bit now but I’ve primarily stuck to lurking for my duration here, scouring the forums for questions that were already solved so as not to be redundant, but now I’m stuck with an uncertainty and the other discussions on this topic haven’t really given me 100% confidence.
I’ve been driving a 2013 G37x Sedan for the last 2/3 months and I recently decided to pick up a set of Enkei RPF1s @ 18x8.5. I’ve had em sitting in my back room for the last week or so while I’ve been getting all the other components together (I.e. lug nuts, center caps, tires, brake pads and brake rotors which I did separately) and now I’m coming close to fruition.
I’ve been stumped, however, by the question of if the OEM TPMS sensors in my stock wheels are transferable to the Enkei’s? I understand it’s a larger diameter on the aftermarket wheels, and worry that that could lead to some complications. Or maybe they just simply aren’t compatible with the Enkei’s. And then I’ve also read that if you’re switching over TPMS sensors that you would need to recalibrate them for the different wheel, and I’m just not sure how that all goes down. Would the Auto Shop that installs my tires and wheels do all this for me? Do I need to take this somewhere else? Am I just stupid? All these questions...
Any help is appreciated.
Old Jun 30, 2019 | 01:12 AM
slartibartfast's Avatar
slartibartfast
Any competent tire shop can swap your TPMS sensors, and they'll fit those Enkeis. Nice choice, by the way. Your old sensors won't lose pairing. Only if you install different sensors do you need to pair them with your car. Again, any competent tire shop can do that.
Old Jun 30, 2019 | 05:18 PM
mark.dtom's Avatar
mark.dtom
Thanks for the info, and I appreciate it, been meaning to switch out OEM wheels from the get go but I had to save up for a minute. So even though the rims are larger diameter I still, in theory, wouldn’t have to have them reprogrammed?
Old Jun 30, 2019 | 05:45 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Diameter has nothing to do with pressure. Volume, yes. Pressure, no. You're overthinking the situation. As Slarti said, keeping your existing sensors will not affect anything. Even if, by some strange reason, the pairing was lost, any competent tire shop can reprogram them in a few minutes and usually no charge- especially if they are mounting the tires in the first place.
Now go get those wheels mounted!
Old Jul 1, 2019 | 12:34 PM
Surfnazi's Avatar
Surfnazi
Temps sensors are universal install some and use tool to relearn it. Discount tire has tool they'll do for free. They charge like 10-15 per wheel to do sensor, free if you have friend there
Matty_baby
Picture Share G Coupe
21
Feb 6, 2019 03:09 AM
iwasgointo
Sep 1, 2010 06:16 PM
JDMHolic
Wheel & Tires
Jul 17, 2009 09:27 PM
rAiN
Apr 3, 2009 06:09 PM
bforbrian
Wheel & Tires
Jan 21, 2009 08:31 PM
