G37 rim question
G37 rim question
I’m looking to get new rims for my 2008 g37 coupe. I found a set from a private seller. They are 5x114.3 bolt pattern. 35 offset in the front, 45 in the rear. They have a centre bore of 67.1 and the G has a 66.1 centre bore. So my question to you guys with more rim experience is, does the larger bore size on the rim have an effect? Will all I need is some hub rings? Thanks
Onurb
Jun 11, 2013 06:40 PM
