Shaking while driving over 20mph.
Old May 25, 2019 | 03:53 AM
EthanWalter's Avatar
EthanWalter
I have a 2008 G37 coupe. Recently started to shake a bit when driving. Doesn't shake at speeds under 20 but somewhere in between 20 and 25 it starts shaking; not a lot, but it's noticable. Shaking sometimes gets a bit worse at higher speeds but when I'm past 80 it stops shaking or if it still shakes it's only a little. uc browser shareit appvn Should this be something I can figure out and fix on my own or is it best to go to a mechanic?uc browser shareit appvn
Old May 25, 2019 | 08:37 AM
telcoman's Avatar
telcoman
Originally Posted by EthanWalter
I have a 2008 G37 coupe. Recently started to shake a bit when driving. Doesn't shake at speeds under 20 but somewhere in between 20 and 25 it starts shaking; not a lot, but it's noticable. Shaking sometimes gets a bit worse at higher speeds but when I'm past 80 it stops shaking or if it still shakes it's only a little. Should this be something I can figure out and fix on my own or is it best to go to a mechanic?
Get a wheel alignment and the tires inspected and balanced.
Telcoman
Old May 25, 2019 | 10:52 AM
Telcoman
x2^^
Are you on stock wheels? If you have aftermarket wheels and do not have hubcentric ring adapters it can induce vibrations at speed.
Old May 25, 2019 | 10:57 AM
slartibartfast's Avatar
slartibartfast
My diagnostic checks in order of likelihood and least cost to remedy.
1: hub ring issue with aftermarket wheel(s)
2: out of balance wheel/tire(s)
3: funky wear from bad alignment
4: bent wheel(s)
Old Oct 18, 2019 | 10:25 AM
dirtnapper56's Avatar
dirtnapper56
bump, ever get this fixed? Having the same issue hoping it's not my prop shaft..
willd828
Dec 29, 2015 11:58 AM
Degenerazn
General Tech Questions
14
Dec 29, 2007 03:04 PM
