Help with g37x 2010
Old Apr 16, 2019 | 11:27 PM
Azwar Imran's Avatar
Azwar Imran
Help with g37x 2010
Hey I got new vossen rims 19x 8.5 front 19x10 in rear I have a 2010 g37x the rims are 5 lug but the rim won't fit do I need a spacer ?? If so I'm been told I need a 5x 114.3 if anyone knows anything about this let me know thanks
Old Apr 17, 2019 | 01:54 AM
symatt's Avatar
symatt
Yes did the seller say what bolt pattern it was? If not try looking behind the wheel to see if it has the bolt pattern. If those wheels are 5x120 for example, then you would need 5x114.3 to 5x120 spacers and not the other way around like 5x120 to 5x114.3
Old Apr 17, 2019 | 09:15 AM
Before you get too deep into this, know that Vossens typically have an aggressive offset, so adding spacer adapters to match the bolt pattern will probably end up poking those wheels and looking pretty goofy.
If you bought wheels with the wrong bolt pattern, and they're new like you said, then return them.
Old Apr 17, 2019 | 03:57 PM
symatt's Avatar
symatt
^ yea what he said, if you think they will stick out too much another option you would have is to have the bolt pattern redrilled to 5x114.3 if you really want to keep the wheels.
nK-
Mar 28, 2016 11:26 PM
rhdh104
Jul 8, 2015 01:43 PM
rcold37
Jan 3, 2014 04:34 PM
XPO_382
Jun 14, 2012 04:13 AM
El Gabito
Aug 20, 2011 08:23 PM
