Will 18x8+45offset fit a 265/35r18 tire?
Old Feb 20, 2019 | 12:31 PM
G37xManiac's Avatar
G37xManiac
I have a 2012 Infiniti G37x sedan and am trying to figure out the maximum amount of tire I can get on some aftermarket wheels. I am currently looking at some Sparco Assetto Gara wheels (18x8 +45mm offset) for the car. Ideally, I'd like to go 18x8.5-9, but tirerack won't let me even see those wheels since I put in my car information. Ideally, I'd like to put 265 tires on whatever wheel I get but the issues of fit and tire rub come to mind. I'd be willing to settle with 255s but don't want to go that small. So do y'all think I could safely fit 265s on these wheels and not have any issues with tire rub? 255s?
In the future, I plan on putting aftermarket Hawk HPS brake pads on the car too so I may need to go bigger than 18x8 just for that reason alone. Let me know if y'all have any suggestions.
Also, I have her on swift spring lowering coils which drop her -1.3" in the front and -1.0" in the back.
Last edited by G37xManiac; Feb 20, 2019 at 12:45 PM. Reason: Forgot to mention something.
Old Feb 20, 2019 | 12:41 PM
SupraOfDoom's Avatar
SupraOfDoom
https://www.myg37.com/forums/wheels-...hread-160.html
Old Feb 20, 2019 | 01:03 PM
ryanwhite74115's Avatar
ryanwhite74115
Buy a different wheel. 265...I have a 275 on a 10.5" wheel. My tire is marginally wider than what you are proposing but my wheel/rim would be 2.5" wider. Can you visualize the difference? I would look at a 9.5-10" wheel if you want a 265.
Old Feb 20, 2019 | 01:13 PM
ryanwhite74115
I'll be honest there's a reason I got custom monoblock wheels. It cost $2600 shipped (which is cheap honestly for those wheels) but they fit flawlessly on the borehub (66.1mm I believe). I need no spacers, no hub adapters, no nothing. Offset is perfect for my big factory brakes. Everything fits as the wheel was designed for my car. Obviously if I sell the car I can only sell to another Nissan or Inifiniti so there's a downside, albeit small.
https://www.bcforged-na.com/monoblock/rs43/
Old Feb 20, 2019 | 01:32 PM
G37xManiac's Avatar
G37xManiac
Ok so I found some Enkei's that are 18x9.5 with 35mm offset. Do you think it would rub with 265s?
Old Feb 23, 2019 | 10:40 AM
Be fine in back, front fender isn't flat-rolled like the rear so there may be contact on the very inside of the front fender. If you want to be safe a 255/45 would be better.
rollaspeed1
Feb 15, 2024 10:41 AM
azndoc
Feb 7, 2015 01:05 PM
Bigrez
Jun 11, 2014 11:12 PM
azndoc
Jan 4, 2013 08:05 PM
advan37
Apr 18, 2011 07:39 AM
