Spacers
Are you looking for spacer size or brand reccomendations (or both)? If size, then: Sedan or coupe (I know you posted in coupe section but I try and never assume)? What offset and wheel size do you have?
As far as brand, generally most well known brands are good (e.g. H&R, Eibach, etc.) as long as they are hub-centric. Making sure your wheels are rotating properly isn't an area to skimp on price. Look around the forum there are lots of reviews and discussion on spacer size/types. Also check out the classifieds as there are usually some up for sale.
Also for reference I have a 2013 xS coupe and with the my OEM sport wheels (19x8.5 +43) I ran H&R spacers 20mm (Front) & 25mm (Back) I found that to push the wheel pretty flush to the fender. I am also lowered about 1.25" on Swift springs, if your not lowered and you space out stock wheels on the X it can look a little odd.
Good luck, and welcome to the forum.
b2autodesigns
Wheel & Tires
507
Apr 5, 2018 11:38 AM
lobuzz311
Mar 3, 2017 04:07 PM
