Vossen CV7 Offset Question
Old Jun 1, 2018 | 10:04 AM
6MT>7AT's Avatar
6MT>7AT
Found a good deal on a set of used Vossens CV7s but I'm trying to figure out if they are too aggressive or not. I'm currently at stock height on my 08 g37 coupe and am thinking about buying a set of springs but I'm not sure yet. The specs of the wheels are 19x8.5 +20 and 19x10 +40. I don't want to run any large amount of camber and would like to fit a meaty tire if possible.
Old Jun 1, 2018 | 08:47 PM
Those are decent offsets, you could run 245/40 front 285/35 rear tires, just need to confirm the wheels will clear the big sport brakes (I assume you have a sport based on your username).
Old Jun 1, 2018 | 11:30 PM
6MT>7AT's Avatar
6MT>7AT
Awesome thanks for the reply. Do you think I will poke at all with this set up?
Old Jun 2, 2018 | 08:41 AM
Fronts will be 23mm out from your stock wheels (assuming you still run the OEM 19s), so measure out that much and see what you think. Should be right at the edge. Rears will be out 17mm from where you are now.
NOLA_G
May 9, 2020 11:49 PM
D2-AUTOSPORT
Wheel & Tires
54
Sep 10, 2012 03:21 AM
EndLessg37
Aug 7, 2012 03:59 PM
Mike@Vossen
Wheel & Tires
Jul 13, 2012 10:49 PM
D2-AUTOSPORT
Wheel & Tires
Jun 27, 2012 01:09 PM
