Help Coupe Offset help?
If you're wanting a more flush fit then you'll be wanting some spacers but w/ those specs you can run a lot more tire, like a 295 or even a 305 out back and a 255 front.
Thanks I'd rather have more tire. I'm running the stock wheels with 20 and 25 mm spacers. I'm really not a fan of spacers though.
How much spacing do you need to clear the calipers, should only be a problem in front unless you're dealing w/ a deep dish type setup. If it's just a few mm that you need you should be able to use a 10mm spacer and this would get your front wheel edge pretty close to where the rear would be.
Not bad, just be sure you get a full six turns on the lug nuts when torqued down to 80-85 ft. lbs, or you will need extended studs. Should be ok on a 3mm but you may need a 5mm just to give you a little "comfort", and sometimes extended studs are needed, but ???
The rear fit with the 3mm and looks pretty flush to the quarter. I not running much camber and only dropped on eibach.
I did the whole could overs , control arms...... On my z and didn't want to put the time in this car but it seems ive opened up a can of worms
brevi
Aug 23, 2016 09:35 PM
mjnoles1
Jan 3, 2016 01:43 PM
IP37
Mar 23, 2014 07:32 PM
