19x10.5 inch wheels
Old Apr 8, 2018 | 08:28 PM
TRS's Avatar
TRS
19x10.5 inch wheels
New here, would like to know if 19x10.5 inch rim will fit a G37S Sedan, keeping it stock height?
Thanks,
Old Apr 8, 2018 | 10:50 PM
Welcome to the site! Check the first page on this thread, mylilG and Tbulsara are running 10.5s on 275s, but these are lowered. At stock height w/ no camber adjustment you'd probably have to stretch some 255s so the poke wouldn't be excessive, and you'd have to run pretty conservative offsets, like a +40. And there's some clearance issues at the steering knuckle so you can't go more positive on the offsets there.
https://www.myg37.com/forums/brakes-...post-here.html
Old Apr 9, 2018 | 04:45 AM
TRS's Avatar
TRS
Thanks for your help
So I decided on going 19x10.5 in rear with 19x9 in the front and Ferrara F4 rims keeping stock height. Also not sure which tire to go with in back, 275 or 285. Any suggestions would be appreciated.
Thanks,
Old Apr 9, 2018 | 09:00 AM
Thanks,
Depends on the offsets, do you have them?
Old Apr 9, 2018 | 09:41 AM
TRS's Avatar
TRS
My offset
GM,
Yes, the offset are 19x8.5 w/+35mm offset.
Rear is 19x10.5 w/+38mm offset.
Thanks,
Old Apr 9, 2018 | 08:38 PM
You could run up to a 255/40 front although a 245/40 is a better mount on a 8.5" width. In back your +38 is pretty limiting, a 275/35 should tuck ok but you may have to run a bit more negative camber, a 285 won't clear without pretty high camber, probably -2.5 range. There have been a few that ran 295s on a 10.5 +45, so that 8mm should translate into 2mm more clearance running 275s on your +38
Old Apr 9, 2018 | 08:48 PM
TRS's Avatar
TRS
Received
Thanks for your advice and knowledge, I am going to see how the 275’s do for me. I am going to stick with the 245’s up front. I am hoping the Ferada F4’s work out for me. I called them and they said the rims will clear the big brakes.
Thanks,
Old Apr 9, 2018 | 10:04 PM
Thanks,
Should be a nice set, look forward to install pics!
jeffjcause
Picture Share G Coupe
Dec 28, 2012 12:34 AM
BrZ33
Jan 29, 2012 12:43 PM
Loi
Jan 25, 2011 09:58 PM
kaos2774
Feb 28, 2008 01:24 PM
