Sugestion for tire specs
Old Nov 3, 2017 | 10:00 AM
MystoZay's Avatar
MystoZay
Hi, I still have the OEM suspension and I would like to reduce the gap between the fender and the mag. I currenctly use the recommanded tire spec on 19 inch mags. I would like to know what size of tire I should go with the reduce the gap. If you have photos it would be appreciated. Thank you
My G37S 09
Old Nov 3, 2017 | 03:07 PM
hurleyguys's Avatar
hurleyguys
coils or lowering springs. taller tires might throw the speedo off and maybe VDS. also taller tires will make you car look lifted.
just get coils or springs.
Old Nov 3, 2017 | 04:01 PM
MystoZay's Avatar
MystoZay
Alright. Thanks for the infos ☺
Old Nov 3, 2017 | 08:13 PM
slartibartfast's Avatar
slartibartfast
Plus, taller sidewalls make for sloppier turn-in and softer ride.
Old Nov 21, 2017 | 11:14 PM
ezbme's Avatar
ezbme
I ended up getting some used front tires size 225/45/18. Didn't realize that they were so much different than the 225/50/18. Do you think it would cause any problems with my G?
Old Nov 21, 2017 | 11:48 PM
What are you running in back?
Old Nov 22, 2017 | 12:01 AM
ezbme's Avatar
ezbme
Std size 245 45 18 Turns out these tires are run flats. I always say no to run flats. My gut was telling me not to even go to this place. I was away for like 5 mins getting cash and they already had two of the tires on my rims. Well hopefully I can tolerate them for a year and get rid of them in 2018.
Old Nov 22, 2017 | 02:37 PM
MystoZay's Avatar
MystoZay
I'm running 245/40/19 in the back
Old Nov 22, 2017 | 03:54 PM
stealthee's Avatar
stealthee
This is why you have to do the math every time.
You're almost a full inch shorter. While you are not AWD I still wouldn't run them as they could throw off the ABS and other things that are looking for similar tire speeds front to rear.
