new tires for x
new tires for x
After alot of research I think I've come to a conclusion that I'm going with slightly wider tires on my X coupe. I just want to verify with someone that the Hankook Ventus S1 Noble2 Performance Radial Tire - 245/45R18 100W will fit on my stock 18s. I couldn't find a definitive answer and just want to double check they'll fit before buying. thanks
Use this calculator when trying new setups
You can, it's about a .66% variance front to back (with the back being smaller), you want to keep that under 1%. Keep in mind that the rears typically wear faster so that variance will increase over time, but shouldn't get to the 1% point.
