How often do you guys rotate your tires?
Old Aug 14, 2017 | 09:21 PM
misc's Avatar
misc
Specifically those with awd? just bought some new a/s tires and want to make sure i stick to a good rotation for even wear
Old Aug 14, 2017 | 10:01 PM
If you're running a square (all tires/wheels the same size) and your tires aren't directional a 7-8k mile rotation is a good plan. With summer tires a rotation every 5k is good since they wear much faster.
Old Aug 14, 2017 | 10:38 PM
Epiphany's Avatar
Epiphany
Twice a year when switching my summer and winter tires. Never done an actual rotation.
Old Aug 15, 2017 | 12:07 AM
emerilnut's Avatar
emerilnut
I do mine every 10,000 or so.
Old Aug 15, 2017 | 12:24 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
Every 3k for me
Old Aug 15, 2017 | 02:06 AM
crookncastle's Avatar
crookncastle
every other oil change.
Old Aug 15, 2017 | 06:16 AM
Lego_Maniac's Avatar
Lego_Maniac
^^this
I don't rotate my tires, because they're staggered. But I rotate the tires on my wife's car every other oil change.
Old Aug 15, 2017 | 08:44 AM
ryanwhite74115's Avatar
ryanwhite74115
Never. Directional staggered tires ftl.
Old Aug 15, 2017 | 08:45 AM
ftl, that made me lol
Old Aug 15, 2017 | 11:50 AM
Victory's Avatar
Victory
Every 7500mi.
Old Aug 19, 2017 | 04:22 PM
4DRZ's Avatar
4DRZ
Depending on how you drive most Infiniti/Nissan vehicles recommend every 5,000-6,000 miles.
Old Aug 19, 2017 | 05:59 PM
doublea88's Avatar
doublea88
I also do the 7500-10,000 miles depending on tire condition and tread life. Speaking of rotations, what is the fastest method that you guys use to rotate the tires?
Old Aug 19, 2017 | 07:41 PM
With my square setup I roll up on ramps, jack the back @ the differential, place my rear jack stands. I then use the floor jack to lightly raise the front just off the ramps to complete the wheel swapping. I slightly loosen the lug nuts prior to any jacking to simplify the job. Takes about 15 minutes if I'm just rotating, but every other time I clean the hub, rotor, and wheel mating surfaces w/ wire brushes/wheels, so that takes a bit more time.
Old Aug 19, 2017 | 08:05 PM
doublea88's Avatar
doublea88
Good idea with the ramps , want to try that but i remember not being able to get my jack under the rear of the car, might have to get a low profile jack.
Old Aug 19, 2017 | 09:09 PM
Ricio1991's Avatar
Ricio1991
7k miles or so
