Volk GTS Wheel fitment question
Old Jun 30, 2017 | 02:32 PM
xmajd92's Avatar
xmajd92
I'm looking at some Volk GTS wheels. Staggered setup, 19x9.5+18 & 19x10.5+17. Will this setup clear BBK?
Old Jun 30, 2017 | 03:46 PM
Depends how much lip you run, those offsets are pretty aggressive so you'll have to run some stretched tires &/or camber to get them in the fenders. They should clear the BBK but it's best to send a template to the vendor if they can't confirm as 2 piece wheels can complicate the fit.
https://www.myg37.com/forums/brakes-...templates.html
Old Jun 30, 2017 | 03:48 PM
xmajd92's Avatar
xmajd92
It's from a private seller. He's currently running then on his G35. Sad thing is I can't test fit them because I'm in Houston and he's 13 hours away in El Paso.
Old Jun 30, 2017 | 04:20 PM
xmajd92's Avatar
xmajd92
Here's the link to the show how his fitment is on his G35.
Old Jun 30, 2017 | 04:31 PM
GetYourWheels's Avatar
GetYourWheels
see what disk he has on the fronts.. if its a high disk.. then highly doubt it would clear the OE big brakes.
Old Jun 30, 2017 | 04:36 PM
xmajd92's Avatar
xmajd92
From the video it looks like the non-Brembo brake kit.
Old Jun 30, 2017 | 04:43 PM
GetYourWheels
no no..
you need to know what disk profile those GT-S faces are.
It would either be High Disk, Mid Disk or Low Disk... work uses letters for these and I believe Volk should too..
I could be wrong tho. it's been awhile since I've seen any 3 piece Volk wheels.. Best bet would just be to measure brakes and take it to the wheel or just test mount it.
Old Jun 30, 2017 | 04:44 PM
xmajd92's Avatar
xmajd92
no no..
Oh I see. Let me check.
Old Jun 30, 2017 | 06:43 PM
deeliciousqueen's Avatar
deeliciousqueen
Here is the link:
Volk Racing GT-S wheels from Upgrade Motoring
High disk or (offset A from the chart) are always bbk friendly, low disk not so much.
Old Jun 30, 2017 | 08:29 PM
xmajd92's Avatar
xmajd92
Originally Posted by deeliciousqueen
Here is the link:
Well then it looks like it'll clear then
Old Jun 30, 2017 | 08:51 PM
saywat?'s Avatar
saywat?
the rears are pretty aggressive if u lower the car u will have to probably shave the entire bumper bracket off. the fronts will fit fine imo
Old Jun 30, 2017 | 09:18 PM
xmajd92's Avatar
xmajd92
My current setup right now if it helps with my current ride height. 18x9.5+38 square w/ 15mm spacers all around. 275/40/18 tires.
Old Jun 30, 2017 | 09:21 PM
deeliciousqueen
You'll be fine, get them gts!
Old Jul 2, 2017 | 03:26 AM
xmajd92's Avatar
xmajd92
Purchased them. Will test fit as soon as they come in. If it's too aggressive, I'll get the curb rash fixed and resell.
Old Jul 6, 2017 | 04:27 PM
xmajd92's Avatar
xmajd92
Fitment is perfect! Previous owner had stretched tires. I'm going to run them til the thread wears out. Then I'll get meatier tires on. Volk GTS Wheel fitment question-photo631.jpg
