Michelin Pilot Sport A/S-3 vs Primacy MXM4
Timely
This is very timely for me. I had pretty much the exact question between the two Michelin models, and this confirms for me my lean toward the Pilot Sport A/S3+. Michelin shows a V- and a W-rated version of this tire in my size (225/50R18). The W is only slightly more expensive (~$9/tire), so I'm inclined to go that direction. Any thoughts?
Thanks in advance.
Thanks in advance.
How fast do you plan on going? A "V" is rated for 149mph and "W" is rated for 168mph. If you plan on going over 150 then you should probably get the W, if not then dont worry about it.
I just picked up my car from costco with brand new AS3+, maybe it's just the placebo effect but coming from the OEM ventus tires they already feel better in every aspect!
I was asking to see if the "W" would perform better at lower speeds than the "V".
I recall reading somewhere that higher speed rated tires have stiffer sidewalls. Not sure if it's truth or myth - never compared 2 identical tires but with differing speed rating side by side.
