Spacers on lowered sedan help!!!
Old May 3, 2017 | 11:56 AM
Jessica Heyduk's Avatar
Jessica Heyduk
I have a 2010 Infiniti g37x on 20s with lowering springs I am camboring the rear to 11 degrees and looking for what size spacers I found 25mm ebach with studs I'm not worried about the rear but will the front rub?! Any input please
Old May 3, 2017 | 12:03 PM
Jessica Heyduk
Sorry about the filter this is what it looks like before spaces
Same just farther away
Old May 3, 2017 | 01:47 PM
MaQG37's Avatar
MaQG37
You don't really mean you are doing -11 camber in the rear, do you?
Old May 3, 2017 | 02:18 PM
Jessica Heyduk
That's what the mechanic said that supposed to cambor them
Old May 3, 2017 | 02:27 PM
MaQG37's Avatar
MaQG37
I would not listen to that mechanic. Your car on springs, with those wheels, will look very odd with -11 camber. You don't need it, and I'm speaking from a strictly aesthetic standpoint. I have roughly -6 camber.
The front will probably also poke with the 25MM spacer up front with just lowering springs.
I think you need to take a step back from everything and re-assess the situation.
Old May 3, 2017 | 08:04 PM
Jessica Heyduk
I had bad info. What would you suggest?
Old May 3, 2017 | 08:05 PM
Jessica Heyduk
I want my tires to look like this
Old May 3, 2017 | 08:13 PM
iCrap's Avatar
iCrap
oh.... so you DO want -11 degrees camber then if you want it to look like that...
Old May 3, 2017 | 09:09 PM
Crazyirish's Avatar
Crazyirish
Thats...unfortunate.
Old May 3, 2017 | 09:51 PM
guy from norcal's Avatar
guy from norcal
Your gonna burn through tires like crazy.
Old May 3, 2017 | 11:02 PM
Good luck with that.
Old May 4, 2017 | 07:37 AM
MaQG37's Avatar
MaQG37
Well, you would need front/rear control arms to achieve camber like that. In addition, new suspension, and different wheels/tires. You are easily looking at a few thousand to get what that pictures looks like, if not more.
I suggest you scrap the whole idea. Driving a car like that is like dating a diva, high maintenance always and always got to be worrying about little things here and there. With the little information you have about the idea, it's just going to be a huge headache. Ask me how I know
Old May 4, 2017 | 10:44 AM
r2dmax's Avatar
r2dmax
MaQG37 is correct. I too have lived (a more sensible version) of the "Stance life". Constant issues, worries, etc etc. I won't tell you not to do it, but look at forums like Stanceworks that specialize in that look.
I will say this: If you are into really driving your car, (which I am) that is not for you. Stance is all about Form>Function
