Any issue with staggered wheels on a G37 Journey?
Old Apr 28, 2017 | 12:11 PM
Mad A's Avatar
Mad A
I want to make sure I won't upset the stability/traction control, since stock the Journey sedan comes with the same width wheels/tires all around.
Old Apr 28, 2017 | 10:33 PM
RWD is much less critical regarding tire sizing, but best to keep within 3% of the OEM diameter and your front & rear diameters as close to each other as possible.
Here's a list I posted about the best tire combos for the most common wheel diameters, just need to pick the right width & offset wheels to mount the listed tires properly.
https://www.myg37.com/forums/brakes-...ml#post3992771
Old Apr 29, 2017 | 07:50 AM
No, there's no issue. The stagger on OEM duckfeet for the RWD Sport package is 1", and I have a 1.5" stagger with my Vossens. It pretty common.
Old May 11, 2017 | 02:56 PM
Mad A's Avatar
Mad A
You seem to be a wealth of knowledge on wheels for our platform, can you recommend a proper offset for 18" Enkei RPF1's 8.5" up front and 9.5" in the rear?
Old May 11, 2017 | 04:16 PM
shoot me a PM and I'll check what they have and get back to you tonight.
Old May 11, 2017 | 04:40 PM
Mad A's Avatar
Mad A
Done, thank you!
Old May 12, 2017 | 09:15 PM
chopper's Avatar
chopper
The 2010 sales brochure shows an option for two Sport Wheel packages for the Journey model. The first is "Split 5-spoke 18-inch aluminum alloy wheels with 225/50R18 all-season tires (AWD model)." Door number two was "Split 5-spoke 18-inch aluminum alloy wheels with 225/50R18 tires (front) and 245/45R18 tires (rear) summer performance tires (RWD model)" so apparently the factory had no problem with different size tires on the RWD models. According to the tire size calculator:
https://tiresize.com/calculator/
the difference in tire circumference between the two tire sizes on the RWD choice is 0.2 inches or 5 revs/mile. 225/50R18 has a diameter of 26.9 inches and circumference of 84.3 inches; 245/45R18 has a diameter of 26.7 inches and circumference of 83.8 inches.
