Wheel Rim size recommendation 18" or 19" - G37X
Old Apr 25, 2017 | 01:31 AM
Originally Posted by darckchap
hello ,
i hit one more road bump, today discount tire called me said that Konig is no more making the Matte Black wheel ( Milligram) which i was decided . Also confirmed same with other online wheels dealers.. now looks like back to square one.
now i am thinking of going for 19 inch wheels as i get better option..
Still thinking of flow formed wheels as per recommendation as they are much stronger and lighter. Any recommendations? I am thinking of ACE or Rohana. Matte Black 19x8.5 size so that i can put 245/45 19 or 245/40 19.
please suggest.
Kali
Kali, sorry to hear about that. I'd run a 245/40/19 all around as this is the closest to your OEM diameter.
That said, here's a few that you might look at that have a similar design to the Miligram.
Here's TSW Interlagos in matte black, a 19x9.5 +41 would be a nice flush fit on 245/40/19s.
19x9.5 TSW Interlagos Matte Black (Rotary Forged) Wheels
Rohana and Ace are both decent options if they have the flow formed versions in the style and finish you want.
And I'd give a good look at these, member Ape Factory is running these on his coupe and would fit well on your sedan, and are light weight, and priced very well!
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Club Zen
Here they are on his coupe (with spacers to flush them up on the wider coupe fenders)
https://www.myg37.com/forums/19/2765...ml#post4098675
Old Apr 25, 2017 | 02:11 AM
darckchap's Avatar
darckchap
Thank you very much again.
I like those Buddy club Zen wheels but cannot find any information in there website regarding the make like flow formed or forged or casting wheels .
do you have idea of what kind wheels they are? sorry for too many questions.
Kali
Old Apr 25, 2017 | 11:07 AM
Kali
I'd send a PM to Ape Factory, he does extensive research on all his purchases so he'd be a good source. Also, they only weigh 23 pounds for a 19" wheel w/ many spokes so I'd have to assume they are a flow formed wheel, a regular cast set like that should weigh in the 27 pound range or more. Buddy Club is a reputable wheel brand w/ a good racing heritage, I wouldn't hesitate to recommend them.
Old Apr 26, 2017 | 12:02 AM
darckchap's Avatar
darckchap
Thank you again, i agree with you.
definitely will check with couple of dealers here about buddy club flow formed wheels. now seems like i am narrow down two wheels between Buddy club & SSR Wheels.
Need your inputs on SSR and below GTV02 wheel.
SSR Wheels - SSR GTV02
Thank you again.
Old Apr 26, 2017 | 01:26 AM
Thank you again.
If you've got the budget for the SSR I'd consider the ones that Zahy Matar is going to run. He's going w/ the Nissan 370x factory Nismo wheels, these are a true forged monoblock wheel from Rays, these are made in Japan, are lighter weight, and stronger than flow formed. These won't require any hub ring adapters and you can use your OEM center caps & lug nuts. They are a 19x9.5 +40 so perfect for a 255/40/19 tire, and that offset will be perfect flush fit at the fenders. Here's his posting
https://www.myg37.com/forums/build-t...ml#post4128200
And a link for the wheels~
2016 Nissan 370Z. #D0C003GM3A: Wheel. Wheel, alloy.
And the 2013 Nismo solid gunmetals also 19x9.5 +40 (good vendor BTW)
Wheel, Alloy for 2014 Nissan 370Z|D0C00-1A36A : Quirk Auto Parts | OEM & Aftermarket Car, Truck, SUV, & Van Parts and Accessories
Here's a member that's running them on his sedan running 255/40/19s
https://www.myg37.com/forums/build-t...ml#post4120159
Old Apr 26, 2017 | 11:21 AM
darckchap's Avatar
darckchap
Thank you my friend, but still i am liking the looks and appearance of SSR. Will definitely check wtih NISMO wheels and if they got in black color rays wheel .
Still debating about buddy club, i like the wheel only i am bit hesitate as it got 15 spokes, i dont want to go beyond 10 spoke.
Kali
Old Apr 26, 2017 | 12:14 PM
Kali
Can't argue the look of the SSRs, I'm just trying to make this choice even harder than it already is for you, lol.
I'll see if I can find a few more choices that will keep your head spinning, lol.
Here's the Forgstar CF10, these have many color options and the offsets are cut per order so you can get exactly what you want. I'd contact Jason or Josh at Getyourwheels.com if you like these, they can get any Forgestar you want
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Forgestar CF10 Rotary Forged Wheel (Deep Concave) - 19x9.5 (+2 to +42)
Might be something you like here too~
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Emotion
Old Apr 26, 2017 | 02:14 PM
GetYourWheels's Avatar
GetYourWheels
You're too kind.
Forgestars are a great choice darckchap. Rotary Forged/Flow Formed wheels at a great price and you get the options of any color they offer in their list of standard finishes!
Although they may not have an awesome brand name like SSR, Work, and Volk, at least you won't have to wait couple months for a replacement wheel(s) with Forgestars if something ever bad happened.
Old Apr 26, 2017 | 03:51 PM
darckchap's Avatar
darckchap
oh my friend.. already i am confused and struggling to make my call, already getting headache.. my head is spinning. please help me and make it tough.
Old Apr 29, 2017 | 10:04 PM
darckchap's Avatar
darckchap
Thank you again.
hello Expert ,
looks like after some research narrow down to below three wheels.
TS10 AND TS9 from Enkei and SSR GTV02
Enkei Tuning Series Wheel TS-10 18x8.5 5x114.3 - Black - CorSport
Enkei Tuning Series Wheel TS9 18x8.5 5x114.3 - Matte Black - CorSport
SSR Wheels GTV02 1-Piece Wheel 18x8.5 5x114.3 22/30/40/55mm Offset - Flat Black - CorSport
Need your inputs before making my decision..
Kali
Old Apr 29, 2017 | 11:49 PM
hello Expert ,
Kali
All 3 are quality choices, the top 2 Enkeis in a +35 and the SSR in a +30 offset, all on 245/45/18 tires. The SSRs will be 5mm further out toward the fender vs. the 2 Enkeis.
Your current 17x7.5 +45 as a reference, the Enkeis will be 12mm out for the width and 10mm out for the offset for a net 22mm out toward the fender from your current wheels and the SSRs 5mm further out than that, both will be a nice fit.
Now it's up to you to get it to one choice
Old Apr 30, 2017 | 03:38 AM
darckchap's Avatar
darckchap
Thanks a ton. will speak to the dealer and place order. will keep you updated.
Old May 1, 2017 | 12:17 AM
darckchap's Avatar
darckchap
Hello Expert,
final question. no more questions to bother you .
Today these Rohana RC10 in matte black wheels caught my attention , they look cool and price is attractive before making decision need your inputs as not sure about the making process.
GetYourWheels.com: Rohana Wheels Rohana RC10 Matte Black Wheels : Wheel and Tire Packages|Staggered Wheels|Custom Wheels|Luxury Rims
Thank you again,
Kali
Old May 1, 2017 | 10:16 AM
  #29
Those would be a notch below the SSRs as these are low pressure cell cast, so the weight will be higher for the same strength. The spokes don't extend to the outer edge of the barrel, IMO it looks better when the spokes go all the way out, but that's just my opinion Niche Essen might be worth a look if you like the RC10s.
http://www.nicheroadwheels.com/essen-m147-w-12799.htm
Old May 1, 2017 | 05:37 PM
  #30
darckchap's Avatar
darckchap
Thank you Sir.
