Help Tire Size for new wheels.
Old Feb 25, 2017 | 04:24 PM
Mach370's Avatar
Mach370
What's up fellas!
I have a 2010 G37S coupe. I just received a set of vertini wheels: F19x8.5 +15 and R19x9.5 +20
What size tires should I be running? I don't want any rubbing and the car is currently lowered on Tein H-Tech springs. Thanks?
Old Feb 25, 2017 | 05:11 PM
Probably best to keep on the narrow side to avoid any issues if you plan to run camber in-spec. A 225/45/19 front 245/40/19 rear should get you just inside the fenders and still be a safe mount on those wheels. You may have just a bit more room to run a 235/45 & 255/40 but it will be close.
Old Feb 25, 2017 | 05:24 PM
Mach370's Avatar
Mach370
That's way too narrow. The fronts I know I'll be okay with 245/35/19 but the rear I was thinking 265/30/19 or 265/35/19?
Old Feb 26, 2017 | 12:59 AM
If you want to give that combo a shot I'd run 245/40~265/35 just to keep diameters closer to oem, unless you're really wanting the shorter sidewalls. I tend to sway towards more conservative fitment as one persons flush is another's poke, lol.
Old Mar 1, 2017 | 05:06 PM
Surfnazi's Avatar
Surfnazi
I ran 245 and 275 with no issues
Old Mar 1, 2017 | 06:54 PM
Mach370's Avatar
Mach370
Got it sorted out fellas, ended up with 245/35/19 front and 265/30/19 rear. +15 offset front and +20 offset rear. No spacers, no mods, no rubbing issues at all. Thanks again for all your input./feedback
Old Mar 1, 2017 | 07:28 PM
VenomGT9's Avatar
VenomGT9
congrats on completely disregarding the input others gave you
30 profile in the rear is going to look and feel awful
Old Mar 1, 2017 | 07:32 PM
Mach370's Avatar
Mach370
On the contrary- it feels right. But then, to each their own. Thanks man!
