Wheel spacer question
Old Nov 13, 2016 | 02:15 PM
celwin's Avatar
celwin
I know 5mm spacers does not require extended lugs. What I don't know is if 10 or 12mm spacers require them?
Old Nov 13, 2016 | 08:13 PM
the93owner's Avatar
the93owner
Definitely.
Old Nov 13, 2016 | 08:51 PM
Even some 5mm spacers require them depending on how deep your lug holes are. Need to get at least 6 full turns on your lug nuts when torqued to 80 ft lbs.
Old Nov 15, 2016 | 08:21 PM
saywat?'s Avatar
saywat?
get 15mm with lugs already in them
Old Nov 17, 2016 | 04:24 PM
C1Forged's Avatar
C1Forged
This is a common misconception in regards to how much thread needs to be held by the lug nut to be safe. There is no magic number of turns, the standard rating in order for it to be deemed safe, is for the lug nut to hold as much thread as the stud bolt is thick.
Old Nov 17, 2016 | 07:23 PM
IIRC the thread pitch and stud thickness in the case of the Nissan/Infiniti 12x1.25 translates to that 6 full turns but YMMV
Old Nov 18, 2016 | 07:22 PM
C1Forged's Avatar
C1Forged
On my current car two wheels ago I measured it out and on the 12x1.25 turned out to be 4 turns since you measure the bolt thickness, not including the threads.
