wheel question
Old Sep 8, 2016 | 10:42 PM
jellyvish's Avatar
jellyvish
wheel question
i have a 2008 G37-S coupe
my roommate has a 2011 lexus IS-F
he's getting some new wheels and said i can use his old ones (stock)... think they should fit? they are same size (19s), his are a tad wider in the back
Old Sep 8, 2016 | 11:14 PM
If they are the are the OEM Lexus wheels they have a hub bore of 60.1mm, they won't fit over the Infiniti hub that's 66.1mm, you would need a spacer.
Old Sep 9, 2016 | 12:59 AM
jellyvish's Avatar
jellyvish
thanks.. so with spacers should be no prob?
Old Sep 9, 2016 | 08:24 AM
Not sure if you can get some hubcentric adapter to keep the spacer 100% on center. A regular (non hub-centric) spacer could cause some vibration issues. You might want to give Charles at B2 Autodesigns a call and see if they make a spacer that would work to adapt the Lexus/Infiniti hub bores. Those IS-F wheels are nice so it would be worth a shot, and you may be fine w/ just the regular spacers too.
Old Sep 9, 2016 | 09:55 AM
VenomGT9's Avatar
VenomGT9
Pretty sure the offsets are like 45mm front (19x8) and 55mm rear (19x9) so you'd definitely need spacers either way. To me, it's not even worth it
Old Sep 9, 2016 | 07:08 PM
jellyvish's Avatar
jellyvish
thanks for the feedback!
Old Sep 9, 2016 | 09:47 PM
saywat?'s Avatar
saywat?
im sure u can buy hub rings make it fit they come in all diff sizes now days
SneakyBrown
Oct 13, 2016 06:48 PM
G37xsfun
Oct 1, 2016 12:13 AM
08G37Coupe
Sep 6, 2016 10:08 AM
lil_dave
Sep 5, 2016 07:36 PM
