Wheel/tire sizes on G37x Sedan w/ swift springs
Old Jun 28, 2016 | 04:05 PM
G37X GraSdadow's Avatar
G37X GraSdadow
I tried to find original 18" 19" Spec for X sedans but it's really hard to find it..
So after some research I found following would be best for car(11 g37x sedan w/ swift springs and 20mm spacers all around)
Option 1) 19" OEM Sport rims (Front only).
Thinking about getting four 19x8.5 Front wheels with 245/40s all around.
Option 2) 19" OEM Sport rims (full)
19x8.5 Front / 19x9.0 Rear wheels with 245/40s all around.
option 3) 18" OEM Sport rims (full)
18x7.5 all around with 225/50s
Since I have swift springs with 20mm spacers all around, I'm not sure which would be the most fitted size for me.
Which set up do you think it will fit the best for my X?
Thank you!
Old Jun 28, 2016 | 07:30 PM
Thank you!
19s FTW, doesn't really matter if they are staggered since it's only 1/2" and the staggered sets are much easier to source.
If you still have the OEM 17s, use them for a skinny winter set and get some nice wider summer tires for the rest of the year, you'll be glad you did.
Old Jun 29, 2016 | 05:00 PM
G37X GraSdadow
Thank you!!
DRAG DR48 CHARCOAL GRAY 19X8 WITH 5-112 BOLT PATTERN LIKE NEW SET OF 4
do you think this would fit on my car?
Old Jun 29, 2016 | 06:36 PM
defektion's Avatar
defektion
The bolt pattern won't work. 5x114.3 is what you're looking for.
Old Jun 30, 2016 | 07:45 AM
ANMVQ's Avatar
ANMVQ
Either would fit and look great, I run summer 19's no spacers and then in the winter I run RWD sedan sport wheels, 20 MM spacers all around.
Old Jun 30, 2016 | 09:11 AM
G37X GraSdadow
without no spacers with swift?
doesnt it look tucked in without spacers?
Old Jul 4, 2016 | 05:16 PM
G37X GraSdadow
Ok.
I'm going to get these anniversary edition 19" wheels next week or so.
19x8.5
19x9.0
Planning to put 245/40 but my question is which direction ahould I do the tire rotation?
Is it even possible?
Old Jul 4, 2016 | 05:35 PM
Ok.
19x8.5
19x9.0
You need to keep the narrow wheels in front so if you have assymetric (outside is stamped on the sidewall)
or non-directional tires, the best you can do is a side to side rotation, or a complete dismount/remount/rebalance to do a true 4 tire rotation.
Old Jul 4, 2016 | 06:58 PM
G37X GraSdadow
side by side rotation you mean like switching front and rear tires on the same side?
Is it even effective?
dismount/remount/rebalance tire rotation sounds like an expensive rotation
Maybe I should consider getting same size wheels for ez tire rotation
Old Jul 4, 2016 | 08:27 PM
No, side to side would mean just swapping your drivers side front to your passenger side front and vice versa and same in the rear. It isn't too effective but better than doing nothing.
And yes, the remount option isn't a great one either unless you got a pal that owns a shop
Old Jul 5, 2016 | 08:42 AM
ANMVQ's Avatar
ANMVQ
My 19's the offset I got I made sure they would be flush, The stock sport wheels I run 20MM spacers( Winters)
Old Jul 29, 2016 | 06:47 PM
G37X GraSdadow
I'm such a noob and I need to calarify..
If I do side by side tire rotation, what about the tire direction? Do I just ignore it ? On the tire, there is arrow indicating it's direction. And if I do side by side rotation, the directions for both side would be opposite..
Old Jul 29, 2016 | 07:28 PM
You can only do side to side if your tires are stamped "outside" on the sidewall or are unidirectional. If they have a directional arrow you'd have to dismount/remount them
Old Jul 29, 2016 | 07:42 PM
G37X GraSdadow
I guess Ill pass on tire rotations..
Just picked up really good condition 19"s with tires for only $600
245s on rear are pretty much useless but 225s on front are in decent shape.
I probably sell the 225s separately and pick up new tires(one of the tires that you suggested, thank you) soon.
I'm still considering trading the 9.0's to 8.5's so I can have square set.. so I can do tire rotations.. haha.. but its hard to find 2x8.5's or 2x9.0's near my area in same condition.
Old Jul 30, 2016 | 05:11 PM
beto4632's Avatar
beto4632
Im running 255/40/19 all around on the sport wheels on my x I'm lowered on eibach running 15mm spacers on back still need to get 20mm for the front I love the look
