Help Buying rims, need help
Old Apr 13, 2016 | 11:36 AM
MNoriegaG37s's Avatar
MNoriegaG37s
Found a set of 20inch Vossen Wheels, need to know if they will fit on my G37s, w/o rolling fenders. The bolt pattern is correct, 275/30/20 on the back. Front 225/35/20. Front are 9 wide. Back 10.5 wide.
Old Apr 13, 2016 | 11:41 AM
VenomGT9's Avatar
VenomGT9
1. Wheels, not rims
2. Fender rolling isn't a bad thing and actually helps fitment.
3. You probably need to trim the rear bracket.
4. What are the offsets? Necessary info
5. Front tire size is not a proper size to run given the rear size, you'll want to run 245/35 if you keep the 275 rear.
Old Apr 13, 2016 | 02:03 PM
MNoriegaG37s
Originally Posted by VenomGT9
1. Wheels, not rims
No fender rolling isn't a bad thing, just want to avoid, If possible. So what would be an appropriate offset?
Old Apr 13, 2016 | 02:18 PM
VenomGT9's Avatar
VenomGT9
Depends on many factors...ride height, camber (camber kits, if you have them) driving intent, tire sizes
Old Apr 15, 2016 | 09:49 AM
OP, do you have a coupe or sedan?
PNW_IPL
May 19, 2016 02:16 PM
al3cks
Apr 29, 2016 10:06 AM
TVPostSound
Apr 26, 2016 07:15 PM
Pimpani
Apr 20, 2016 01:20 PM
Ihtbealexxx
Apr 7, 2016 05:50 PM
