Vossen CV2 offsets
Old Mar 22, 2016 | 04:23 PM
pal51961's Avatar
pal51961
Vossen CV2 offsets
Has anyone run Vossen CV2's on their S coupe with 20/25 offsets? If so can you verify or describe the fitment, thanks. I have researched this but can not find a definitive answer, so I need to hear it from the horse's mouth.
Old Mar 22, 2016 | 04:58 PM
juan goose's Avatar
juan goose
The wheels are 20x9 +20 and 20x10.5 +25 and tires are 245/35R20 95W at the front and 275/30ZR20 97W at the back.
Courtesy of blnewt. He helped me very much on this.
Should be a pretty flush setup, here's one that's real close to what you listed for reference
https://www.myg37.com/forums/wheels-a...ml#post3471382
That G is going to be 6mm further out in front and 5mm further inside on the rear tire. I think if you can find a 10.5 +30 that would be better w/ those 275s, or a 10" +25. Otherwise you may have to run camber a bit over -2 degrees.
Old Mar 22, 2016 | 09:04 PM
pal51961's Avatar
pal51961
Actually the tires on this set are 285's in the rear. Do you think that will be an issue?
Old Mar 23, 2016 | 01:04 AM
juan goose's Avatar
juan goose
What I posted is what I have on myg37. You will have to trim the rear bumper bracket
Old Mar 23, 2016 | 01:23 PM
300ZXTT's Avatar
300ZXTT
Yes, 285 will be an issue with a +25 offset in the rear with a caveat:
Are you lowered with springs or coilovers? If not, 285 series tire with a +25 offset probably will work, but will not look optimal in appearance. Depending on how much you're lowered (if you are), you'll likely rub or at the very least need to trim the fender liner, etc. Your camber, if you're lowered, will also play a factor.
Plenty of info here about what works/doesn't:
https://www.myg37.com/forums/wheels-...d-post-up.html
Old Mar 23, 2016 | 01:41 PM
pal51961's Avatar
pal51961
I am lowered on Swift springs about 1.5 inches.
Need 4 Speed
Wheel & Tires
40
Sep 22, 2016 07:51 PM
Envee
Mar 30, 2016 10:28 PM
2013G
Mar 29, 2016 09:09 PM
69GTOFarm
G37 Convertible
Mar 23, 2016 02:52 PM
pal51961
Mar 20, 2016 11:47 PM
