Help Choosing 18x8.5 wheels for g37x - Need Advice
Old Jan 28, 2016 | 01:04 PM
Brochenko's Avatar
Brochenko
So after spending about a month researching, I've narrowed down my search to three wheels that I find will look appealing on my g37. I did a lot of thinking about getting 19" but in the end the drop wouldn't work well with the roads/area I drive in..
These are the finalists:
Rays 57xtreme: Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Rays Gramlight 57Xtreme Wheel - 18x8.5/ 5x114.3 / Offset +33
Forgestar F14's (18x8.5 +35 offset): Forgestar Wheels Custom Rotary Forged Flow Formed Concave Performance Wheels - Forgestar F14
Enkei GTC01: Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Enkei GTC01 18x8.5 / 5x114.3 / +35 (hyper black)
I feel that these three would look good in 18" without a drop ... Now the tough part is choosing which one. I'm honestly stumped, and I cannot decide!
I've searched around and found a few pictures for the GTC01's in 18" on a g37 but I can't find any for the other two in 18" on a g.
I know choosing a wheel can make or break the look, therefore I'm looking for opinions, advice, feedback, etc. on how of these wheels might look on my black g37x (picture for visual reference)
Thanks!
Old Jan 28, 2016 | 03:50 PM
I'd give a look at these Work Emotion in 18x 9.5 if you want a bit more tire that is
Bronze would look sweet!
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Work CR Kiwami
Old Jan 28, 2016 | 05:06 PM
Brochenko's Avatar
Brochenko
Those look pretty nice! Especially with the 9.5 width and deep concave. What offset and tire size would you recommend for the 18x9.5? I see they have +30 and +38. With the 9.5 width, I wouldn't get any rubbing or issues with a square setup on an X?
Old Jan 28, 2016 | 09:46 PM
9.5 +38 on 245/45/18 will fit well, be nice & flush but won't cause problems, here's the same fitment except he's running 255s, the 245s will give you 5mm relief at the fender which I'd recommend.
To 18s back i go! - G35Driver
Here's another nice choice IMO
http://www.evasivemotorsports.com/mm...ode=WEDS-SA72R
Old Jan 29, 2016 | 10:20 AM
Brochenko's Avatar
Brochenko
So the 5mm relief won't cause any rubbing at full lock? It doesn't seem like a lot of space? (correct me if I'm wrong). Those WedsSports look really nice too. Hmm decisions...
So I know you can't use OEM lug nuts, what set would you recommend blnewt?
Old Jan 29, 2016 | 02:04 PM
You'll be good lock to lock, as far as lug nuts, the gorilla "System" is decent and has a set of 4 locks included, check amazon, just be sure to get the 12x1.25 set.
Amazon.com: Gorilla Automotive 71623N "The System" Acorn Wheel Locks (12mm x 1.25 Thread Size) - For 5 Lug Wheels: Automotive Amazon.com: Gorilla Automotive 71623N "The System" Acorn Wheel Locks (12mm x 1.25 Thread Size) - For 5 Lug Wheels: Automotive
Old Jan 30, 2016 | 02:11 PM
Might get in touch w/ Jason at GetYourWheels, seems to be running some nice deals on Weds, and if you look at a few posts above this one you'll really see how nice & concave they are, and those 9.5s only weigh about 20 lbs.
https://www.myg37.com/forums/wheels-...ml#post3987992
Old Jan 31, 2016 | 06:56 PM
Brochenko's Avatar
Brochenko
Ugh so many good looking ones, now I gotta pick a set... I never knew choosing wheels would be this hard Those weds do look really nice...
Thanks for all your help blnewt!
Old Jan 31, 2016 | 10:49 PM
It is hard, I wish I would've taken more time when I picked mine, there's always something that you think would've worked out better, lol.
Here's one more photo that may interest you, it's a square 19x9 +30 without any suspension drop, this will show you how those 9.5 +38s on a 245 will fit at the fender at stock height, the 9.5s will actually be a bit over 1mm inside from these so just about identical fit with just a fingernail more wiggle room, lol.
https://www.myg37.com/forums/brakes-...ml#post3820866
Good Luck
Daddy Fat Sacs
30
May 15, 2016 02:01 PM
rhdh104
Mar 11, 2016 10:04 PM
hevak
Feb 17, 2016 12:12 AM
CRiME
Jan 31, 2016 11:16 AM
Jan 24, 2016 09:18 PM
