Would these Wheels fit on the car?
Old Nov 30, 2015 | 10:35 PM
humzakhan's Avatar
humzakhan
I need a pair of winter tires for my Infiniti G37S Coupe from 2008. I found a pair of wheels and tires that were used on a 2012 Audi A6 3.0T for just one winter and have very good tread. I currently have the stock 19" wheels on the car and want to know if these would fit. Here are the specs of the wheels and tires.
Wheels: Moda MD11
Offset: 32mm
Bolt Pattern: 5-112
Weight: 24.4lbs.
Construction: 1pc. Low Pressure Cast
Tires: Bridgestone Blizzak LM-60
225/50R18 95H
Starting Tread Depth: 11/32
Current Tread remaining: 9/32
I want to know, would these fit on my Infiniti and would they be good for the Winter? Thank you.
Old Nov 30, 2015 | 11:23 PM
Wheels: Moda MD11
Offset: 32mm
Bolt Pattern: 5-112
Weight: 24.4lbs.
225/50R18 95H
That's the wrong bolt pattern, Infiniti uses a 5x114.4 or 5x4.5. Check our classifieds, there's some coupe 18s for a nice price.
If you really want those wheels you'd need a adapter, and your coupe is an S model so you'd have to confirm caliper clearance.
Landshark
25
May 26, 2016 06:34 AM
Ayeetyy
Apr 3, 2016 08:26 AM
Ayeetyy
Mar 23, 2016 02:48 PM
parkern
Dec 7, 2015 09:41 AM
SiKHG37
Nov 30, 2015 09:27 PM
