Hub Centric Ring question
Hello,
I have a 2012 g37S Sedan and recently had to remove my Ace Mesh-7 wheels 20x8.5/10. Upon removing them the shop damaged the hub centric rings and they are unable to determine what size I need for when I put the wheels back on.
Wheels were purchased from original owner with the car and I am unsure of offsets.
Could anyone please guide me in the right direction so I could order the correct size needed? I am sending the wheels off to be refinished and will need the rings prior to.
Thanks in advance!
Thanks in advance!
72.56-66.1
I'd call them to confirm that 72.56 is the default hub bore for an Infiniti wheel. I was going off the info on a website. If they say yea then you'll need to get 72.56 to 66.1 hub ring.
http://www.vibemotorsports.com/store...niti-g37-sedan
