set of vossen cv3 19x8.5 and 19x9.5 from a scion fr-s fit on 2013 g37s sedan?
Old Jun 1, 2015 | 07:36 PM
larfboy's Avatar
larfboy
I have a seller selling a set of Vossen CV3 19x8.5 in front and 19x10 in the rear from a Scion FR-S and was wondering if this set would be able to fit into the G37S.
It is a great offer i found and if all it would take to fit these on my car was a bolt adapter, then i am considering pulling the trigger on this.
Old Jun 1, 2015 | 08:11 PM
HoldmyMouse's Avatar
HoldmyMouse
Do you know the offset? The spacer to change bolt pattern would add perhaps another 10mm.
Old Jun 1, 2015 | 08:16 PM
Bolt pattern is a 5x100 and would have to verify offsets. If you have enough positive offset to run the spacer/adapter it could be done.
Old Jun 1, 2015 | 08:27 PM
larfboy's Avatar
larfboy
he says it's +42
Old Jun 1, 2015 | 08:31 PM
larfboy's Avatar
larfboy
nevermind +45 in front +50 for rears
Old Jun 1, 2015 | 10:57 PM
If you can find a 15mm adapter thats listed as 5x114.3 to 5x100 that would work~
This would net a 8.5+30 front and 10"+35 rear, those offset would work as long as the wheels clear the big brakes (they should be should contact vendor/seller to verify, these templates are handy to send them if needed
https://conceptzperformance.com/imag...nttemplate.pdf
https://conceptzperformance.com/imag...artemplate.pdf
One of your posts you said a 8.5 & 9.5, the other you said a 10" rear.
If you have the 8.5/10 combo I'd run 245/40/19 front 265/35/19 rear, those tires would also work fine if you have the 9.5" rear.
Even better if you could find a 10mm thick adapter, not sure about that
Old Jun 2, 2015 | 12:18 PM
larfboy's Avatar
larfboy
it's a 8.5/10...i wrote the thread title incorrectly and couldn't edit it.
so i see that on the website you provided, there are 15mm and 11mm..if the 10mm thick adapter would be better than the 15mm, then would the 11mm be better than the 15mm as well?
Old Jun 2, 2015 | 02:16 PM
HoldmyMouse
With your listed offsets, you might want to run thicker adaptor like 25mm front and 20mm rear to bring your wheels semi flush.
superjoey
31
Mar 22, 2023 11:56 PM
ericmadGRR
Apr 26, 2016 01:27 AM
WhyUmadMFKR510
Northern California
20
Oct 13, 2015 03:04 AM
sharmelan
Aug 25, 2015 03:41 PM
