Tire Pressure
Old May 18, 2015 | 08:29 PM
G37xhibeet's Avatar
G37xhibeet
Tire Pressure
Correct me if I'm wrong, but wheel size has nothing to do with recommended tire pressure right? This is the first time I've checked my tire pressure since I had my new wheels put on. According to the door, I should be using 33psi but what I found was FL: 34.5, FR: 36.5, RL: 38, RR: 37.5. Sorry for sounding like a newb but, is that a problem?
Old May 19, 2015 | 12:11 AM
Tire brands/tire types can vary in pressure requirements. I'd use the 33 as a minimum and 40 as a maximum (35 seems to be pretty good for most cases). If you go much lower than 33 the TPMS light may go on, especially in cold temps. I would be sure to get all your tires within 1 psi of each other
Old May 19, 2015 | 09:26 AM
G37xhibeet's Avatar
G37xhibeet
Thanks newt. I was thinking I'd get all 4 to 36psi
Old May 19, 2015 | 07:53 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
You'll need at least the door jamb pressures to support vehicle weight properly. You also don't want to exceed the tires max psi mentioned on the sidewall. Anything between the two, tuned in a couple pound increments until you get the feel/handling you're after, will work fine.
Old May 26, 2015 | 06:54 PM
RadioFlyer's Avatar
RadioFlyer
[Snip]...what I found was FL: 34.5, FR: 36.5, RL: 38, RR: 37.5. Sorry for sounding like a newb but, is that a problem?
^ That sounds like someone was trying to do the TPMS reset, and didn't inflate the tires after the procedure was done.
Old May 26, 2015 | 07:57 PM
G37xhibeet's Avatar
G37xhibeet
Yeah I think I found a sweet spot with 36psi front and 37psi rear. Any more than that up front and the vibration is unbearable
Old May 26, 2015 | 11:57 PM
Shouldn't have vibration, did you install hub adapter rings w/ those new wheels?
Old May 27, 2015 | 12:05 AM
G37xhibeet's Avatar
G37xhibeet
I did install hub rings, and that's what I thought. But I did get vibration in the steering wheel. I deflated them to 36, thinking that shouldn't make a difference, but it did.
RYs06MT
Apr 22, 2016 11:00 AM
Juancgn33
Sep 10, 2015 07:25 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
footballmania32
Sep 4, 2015 02:17 PM
