2010 xS A edition sedan wheel setup
So I picked up a 2010 G37xS AE edition last summer. Love the car!!!
I am currently looking for advice on the best square setup for the car at stock height. Looking for 20" concave look. Vossen possibly. I guess I need to know how wide of a rim will work and look good if I lower it in the future. Also what offset to run. I am looking to spend around 2k give or take a few hundo, for tires and rims. This will be my summer setup. I have the AE rims with blizzaks for winter. I also plan on lowering it a bit to make it look good, but not be too low because I do live in UPPER Michigan which gets ALOT of snow.
I also want them to clear a bbk because I am looking for that setup as well. I want to do it inexpensive but safe for sure. Any help is appreciated. I have been lurking and searching forever just to get confused with the variations for the x model sedan.
Thanks,
Thanks,
Thanks,
Thanks,
https://www.myg37.com/forums/build-t...d-journey.html
He's also running a square 18" setup but his offsets will apply. Running 9.5 +45s all around on 245 width tires.
If you're planning a mild drop I'd run no larger than 19s, they'll look better, if you drop a bit deeper (and it sounds like that's not an option w/ the roads you have) then 20s will look good.
Shoot for a 9" to 9.5" rim w/ a +40 offset on the 9s and a +45 on the 9.5". Also you MUST confirm w/ the vendor for brake clearance, many wheels won't work.
Save these templates, you might have to send them to the vendor
https://conceptzperformance.com/imag...nttemplate.pdf
https://conceptzperformance.com/imag...artemplate.pdf
Also check this thread for BBK upgrade, be sure to read the update in red on the first post
https://www.myg37.com/forums/brakes-...the-cheap.html
if you want the deep concave look, you wont get that with a 9.5, you need to 10 and wider, that being said, you wont clear the BBk... i had 10.5 stance sc5 (look like vossens) +35 offset wrapped in 275/25/20
once i installed the BBK, i had to put a spacer in the front.
im now running a 10.5 avantgarde m310 and love them... the design of the wheel allows the wide wheel while allowing enough clearance for the BBK
