spacer install
Old May 12, 2015 | 02:58 PM
xxg00w0's Avatar
xxg00w0
spacer install
I need help guys, I bought these spacer from B2 Designs and my shop told me that I need longer studs in order to install them. anybody have them install before?
B2 Auto Designs
Old May 12, 2015 | 03:09 PM
ChinkyChoy's Avatar
ChinkyChoy
B2 Auto Designs
yeah so you need longer studs because with the spacers you may not have enough thread for you lugs to grab.
You should have gotten the spacers with the built in studs if available in that size.
but its a quick fix just buy extended studs and hammer out your old ones and use the washer and open nut technique to pull them through or borrow one of those special tools to do it
Old May 12, 2015 | 03:55 PM
xxg00w0's Avatar
xxg00w0
But the point is the spacer already comes with extended studs.. not long enough? here is the link where I bought
B2DESIGNS Wheel Spacer 2 Kits 10mm w Extended Studs 350Z 370Z Infiniti G35 G37 | eBay
Old May 12, 2015 | 03:59 PM
The studs included should be the ones you need, if they sent you the wrong studs contact the vendor.
B2Autodesigns is great vendor on our site. Contact them and ask for Charles, he'll be happy to check out your situation.
Old May 12, 2015 | 04:01 PM
ChinkyChoy's Avatar
ChinkyChoy
Oh didn't know they included the studs they should be the right ones
Old May 12, 2015 | 04:23 PM
xxg00w0's Avatar
xxg00w0
Yea, I think they are great, I just don't know why my shop told me that, I needed longer studs, I didn't want to test fit them because If I did, then I won't be able to return them.
Old May 12, 2015 | 07:10 PM
Maybe someone can chime in and tell you how long the OEM studs are (I don't have that info at the moment) then all you'll need to do is measure the ones that came w/ the spacer to verify if they're the correct length. Or you can just contact Charles @ B2 Autodesigns and he should be able to tell you the exact length of the studs that are supposed to come w/ the kit. They sell hundreds of these spacers so he knows his stuff, probably much more than the place doing the install.
Old May 13, 2015 | 02:46 PM
xxg00w0's Avatar
xxg00w0
any body know how long the OEM studs are?????
Old May 13, 2015 | 03:45 PM
Herostar's Avatar
Herostar
I have an idea: Take off a wheel, measure, compare to spacer.
Intake
Dec 25, 2015 09:38 PM
news1213
Dec 16, 2015 11:06 AM
connoisseurr
Sep 20, 2015 04:14 PM
WillCo1
Aug 25, 2015 02:25 PM
cparise
Aug 19, 2015 01:51 PM
