Proud New Owner w/ Tire Questions
Old May 1, 2015 | 01:33 AM
ButteredToast's Avatar
ButteredToast
Hey guys,
I'm the proud new owner of a 2013 G37x and I love it!
It's running the stock 225/55R17 Goodyear RS-As and I don't really like them. I'm looking to upgrade to either ultra-high performance all-seasons or an ultra-high performance sports. After pouring over tirerack.com for hours, I determined that the best tires don't come in the stock size, but are available in 235/50R17. From my calculations, these would only be a 1.8% rolling diameter difference. They would fit the stock rims and run without a problem right? My favorite at the moment is the Pilot A/S 3.
As far as the all-season vs. summer debate, I'm aware of the responsiveness and handling trade-offs, but what sort of a difference am I looking at in terms of tread life between the two? If the summers will only last half as long that's going to affect how much I'm willing to pay for them.
Don't worry about winter weather. In Virginia I don't see much and I'm confident AWD will carry me through it. If it proves to be an issue I'll slap the RS-As back on and wait out the winter.
Thanks!
P.S. I don't have the money for 18s or 19s right now, so those suggestions, while tempting, can not be considered in my situation =/
Old May 1, 2015 | 08:38 AM
emerilnut's Avatar
emerilnut
Did you compare the treadwear ratings from the UTQG numbers on both tires? If the treadwear numbers are similar, then how long they last will be similar. Not the same, but similar. Comparing those numbers is not really a science, but if one tire's number is half the other's then you'll know they'll get approximately half the life.
Old May 1, 2015 | 09:16 AM
Welcome to the site, congrats on your X and glad you found us!
I'd run 245/50/17s, you'll only be out about 0.37% and you're still within the recommended rim width for that size tire (7 to 8.5")
As far as going w/ summers over A/S, Summers all day long, especially since you have a plan for going back to winter tires when the time comes. It also depends how many miles you're planning on driving, but even then, I'd just bight the bullet w/ the summers, you'll enjoy what your G can really do that way
Old May 1, 2015 | 09:33 AM
Oh My G 523's Avatar
Oh My G 523
Hey blnewt for our x sedans with the 18 inch duck feet. What would you recommend the best fitting. Was thinking of going the Michelin PSS. But I don't know if I should go square all around or do 245's in the front and wider in the rear ?
Old May 1, 2015 | 12:43 PM
HoldmyMouse's Avatar
HoldmyMouse
X ducks are 7.5" wide all around I think, so you wouldn't want to run 245 because they are more for 8" and especially for x you should run square stock 225/50/18 to avoid any issues and you can also rotate for better tire life.
If you don't have to worry about snow then PSS is definitely one of the best sticky summers you can get.
Old May 1, 2015 | 02:10 PM
The 245/45/18s are still Ok on a 7.5, not as good as an 8 but still within the recommended rim range. As far as AWD issues, that tire size won't cause any conflict. Agree about running square and getting most out of your tires w/ true four wheel rotation, and those PSS wear well for summer treads.
Have fun
Old May 1, 2015 | 02:32 PM
HoldmyMouse
I just personally feel 7.5" with 245 will have a balloon looking tire and also affect handling characteristics because 7.5" is the minimum recommended width.
Old May 1, 2015 | 02:36 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Continental DWS
Old May 1, 2015 | 04:10 PM
It's definitely not ideal as you will get rolling of the sidewalls under hard cornering, a wider alternative that's not quite so detrimental would be a 235/50/18, it will be about .4" taller but since there's no front to rear difference it will still work OK for AWD.
Good point about the 245s, even some brands don't go down as narrow as a 7.5 on the 245.
Old May 1, 2015 | 04:47 PM
I see it's just "ducks" now. That's freaking amazing.
Old May 2, 2015 | 08:08 AM
Oh My G 523
Thank you guys, I appreciate the feedback. Just wanted to make sure I get the best size set up, since I do get on her When the weekends come. 😁
Old May 4, 2015 | 11:28 PM
omahawk's Avatar
omahawk
I just picked up a 2011 G37X a couple of weeks ago myself from CarMax. They put on 4 new Goodride SA07 tires in the stock size 17" wheels. I have never heard of this manufacturer and there isn't much information on the internet about them. The reviews I have seen are from Europe and people seem to like them. Does anyone know anything about these tires or the manufacturer?
Old May 4, 2015 | 11:40 PM
Welcome to the site. Seem to get good reviews on some vehicles that are similar to your G in performance. Since they're new and already paid for just run 'em and see what they can do
Some sites list them as All Seasons and others as a Summer tire so would be good to know for sure
Old May 6, 2015 | 05:49 PM
ButteredToast
Thanks for your response! I liked your suggestion of going to 245s, but it really doesn't seem like there are many tires available in that size. How much worse would it be to go to 235s so I have a better selection? For example, The ExtremeContact DW, S-04 Pole Position, and Pilot A/S 3 are only available in a 235/50R17.
Old May 6, 2015 | 10:38 PM
That's actually a better mount on your X wheel, so those would work well
Purist
Feb 26, 2016 01:25 AM
Bennyjoel
Sep 30, 2015 11:56 PM
joebrez
Sep 22, 2015 11:54 AM
JG_G37
Sep 19, 2015 09:07 PM
allen738
Sep 6, 2015 09:36 PM
