Really stupid Question!!!
Old Apr 3, 2015 | 10:29 AM
13BlkG37's Avatar
13BlkG37
I have a 2013 Coupe Journey. It has the 18x8 wheel package. I found some great looking Enkei wheels that come 18x7.5. Is there any reason to be concerned about the half inch width difference??? OK flame me...but I have owned a G since Dec 2002 (totaled August 8th 2014) and just got the G37!!
Old Apr 3, 2015 | 10:43 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Not many people would recommend making the move to a 7.5" wheel, but it's a small difference. The offsets are more important. If you provide those, we can assist you further in determining the fitment. My recommendation is to consider a different wheel though, one that is at least the OEM size or larger, to make sure you don't degrade the handling of the car.
Old Apr 3, 2015 | 10:45 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
You have to worry about offsets, not width. Search around the forum a bit, there are a lot of fitment threads for wheels/tires.
Old Apr 3, 2015 | 11:53 AM
13BlkG37's Avatar
13BlkG37
Wheel Offsets!!
The OEM wheel has a 43mm offset...the enkei STR5 is a 42MM offset. Don't see a problem here. Am I correct??
Old Apr 3, 2015 | 12:08 PM
Ryne's Avatar
Ryne
Well, the combination of the offset and the width will result in the wheel being sunken in 5mm extra. This won't look great and may be an issue if there isn't 5mm of clearance between the caliper and the wheel.
Here is the tool I used (when you click on the link you will see that I preloaded all of your specs):
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Old Apr 3, 2015 | 12:35 PM
South3rn's Avatar
South3rn
Hey, that's a great tool, Ryne! Bookmarked.
I feel a lot better going to 245/45x8.5 30
Old Apr 3, 2015 | 01:57 PM
13BlkG37's Avatar
13BlkG37
Thanks...!
You have been very helpful. Still have some thinking to do. Take a look at the Enkei STR5 wheels and tell me what you think on a black G. Will be adding drilled rotors and painting the calipers black. Again Thanks!!!
djdiskino
Oct 7, 2015 08:31 PM
JG_G37
Sep 19, 2015 09:07 PM
gdaelemans
Sep 15, 2015 12:20 PM
nbast
Sep 14, 2015 12:39 PM
gdaelemans
Sep 13, 2015 09:36 PM
