Does the G35 rays 19'' fit on the g37x 2013
Old Mar 15, 2015 | 01:30 PM
grisensko's Avatar
grisensko
I have a sedan g37x 2013 and I'm looking for 19 inch for the summer. I found a set of rays 19'' from the g35.
Front are 19x8 offset 30
Rear are 19x8.5 offset 33
The used set come with 225/40/19 on the front.
I know that the normal combo is putting 245/40/19 at the back... However this causes 3% difference in diameter and I'm not sure if the awd would cause a problem.
I thought about 235/40/19.. rare dimension ... Or wider 255/35/19... Or even square 225/40/19 could fit on the 8.5 whell...
I would like to know if
1- Would the wheel fit? Or Is the offset too aggressive and would cause the shell to be wider than the car?
2- What tire size would you recommend?
Thanks
Old Mar 15, 2015 | 02:07 PM
Thanks
Just run 245/40/19s all around, the 1/2" stagger will have a minimal effect (if any) on rolling diameter. Wheels will fit in the fender just fine, much better than the OEMs as far as being more flush
Nice quality wheels too!
Old Mar 15, 2015 | 11:04 PM
RexHavoc's Avatar
RexHavoc
What he said. Buy two sets though and run squared!
Old Apr 18, 2015 | 02:39 AM
mickeytl's Avatar
mickeytl
I actually like this setup as well. Would get 19x8.5 all around with 245/40/19 tires.
Old Apr 18, 2015 | 08:37 AM
RexHavoc's Avatar
RexHavoc
I'm loving it on my X. Though I'm heading out today to discuss changing the color for the summer set.
Old May 12, 2015 | 10:01 PM
amciner28's Avatar
amciner28
I have a question about this since I am looking to put the 19" wheels on my 2012 G37x... I want a square setup because of the AWD but it's impossible to find a square set anywhere.
Could I get the staggered set and just put the same size tire on both the front and the rear rims? I'm not sure how tires stretch or if it would be a bad idea
Old May 12, 2015 | 10:45 PM
Baby Jumpman's Avatar
Baby Jumpman
^Yes you can.
Old May 14, 2015 | 12:18 PM
RexHavoc's Avatar
RexHavoc
You can yes. I bought two sets and run them squared though I may eventually decide to sell the set of rears.
Old May 14, 2015 | 05:48 PM
tony76's Avatar
tony76
I would also like to get some 19's. What does run squared mean.
Old May 14, 2015 | 07:36 PM
Run squared just means all 4 wheels & all 4 tires the same size, compared to staggered which have a wider rear wheel & tire setup
Old May 18, 2015 | 10:35 PM
amciner28's Avatar
amciner28
Hey let me know... depending on the type of wheel (10 spoke sport or 9 spoke anniversary is what i'm looking for) I could be interested in buying those... i have around 5/32 left on my tires so it's not a huge rush but i'm up here in Mass so they would need to be shipped
Old Oct 24, 2015 | 07:30 PM
jinya1004's Avatar
jinya1004
Square Setup
Would the rear Ray's Forged 19's fit up front on a G37 sedan?
On my car, the rears fit pretty flush on the back and the fronts a sunken in a bit.
Just wondering before I try it out when I swap out for my winter set.
Also, pictures would be awesome, if the fitment works.
Old Oct 24, 2015 | 08:41 PM
The 8.5 +33 will be a great fit all around, the fronts will be a bit more flush than the rear but won't cause any issues.
Mattlorentzoe
May 24, 2021 08:49 PM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
sharmelan
Aug 25, 2015 03:41 PM
jessebritches
Aug 20, 2015 12:40 AM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
