Eliminating Wheel Gap without looking stupid or lowering.
Old Mar 31, 2015 | 05:16 PM
  #31
Flakman's Avatar
Flakman
I like the look a lot. What in total was done and what were the parts costs if I may ask?
Old Mar 31, 2015 | 07:56 PM
  #32
socketz67's Avatar
socketz67
Community Builder
The Swift Spring rates are modeled off the standard Journey Spring Rates correct?
I believe Tanabe is the only one that based there springs off the sport package suspension, which is significantly different from the Journey.
Old Apr 1, 2015 | 12:51 PM
  #33
bsettles's Avatar
bsettles
Flakman-
Swift Springs (1100 parts and labor)
20% Tint all the way around(175 parts and labor)
OEM 17" painted gloss black (DIY) (65 bucks in paint and supplies)
Tanabe Exhaust (1000 and DIY install)
Whomever asked about the fronts looking tucked
I am not running any spacers right now nor do I have a front camber kit installed and my front alignment is out of spec at -1.9 Left and -1.5 right(backs are both at -1.0). Should I get a front camber kit and if so which one specifically. I guess I feel like I am going to get crazy tire wear with those numbers however the cars feels great on the road.
As far as spacers go would 20mm all around cause any rubbing you think? Maybe just some for the front?
I like the idea of spacers but I still want to load this car up with 4 adults sometimes so I don't want the wheels so flush they rub the fender, they are stock 17" sedan wheels.
As far as other mods not listed in the response to Flakman I have z1 tubes with Injen intakes, and Kinetix HFC's
Old Apr 1, 2015 | 01:18 PM
  #34
Flakman's Avatar
Flakman
Originally Posted by bsettles
Flakman-
Thanks! Was mostly curious about the suspension. My G37xS is running 245/40/19s and have the same wheel gap you had. I like the way your G sits, and if the ride isn't much worse and there's still good ground clearance, I would love to drop mine about the same. With the AWD I'm thinking the spacers may be more of an issue as well (or at least will be to my accountant/wife when I eat through tires).
By the way, are you running stock shocks or aftermarket?
Old Apr 1, 2015 | 03:13 PM
  #35
bsettles's Avatar
bsettles
Stock shocks, I will upgrade when they go but I drive mostly all highway so it may be a while. I still have the stock shocks on my DD and it has 170k miles.
Old May 20, 2015 | 09:18 PM
  #36
pulleyjk's Avatar
pulleyjk
Great topic. Have a 2012 G-37s Coupe with stock 19" wheels. Stock suspension. Getting curb rash and don't like the stretched tire "racer" look. Looking to add tire section/tread width with same or slightly taller OA dia. Best I can find is F 255/40 (+1.19 w and +.06 ht) and R 285/35 (+1.58" w and +.14 ht). Sumitomo HTR Z3. Will these rub? Front? Rear?
Thanks for any help!!
Old May 20, 2015 | 09:27 PM
  #37
I'd run the 255/40 front 275/35 rear, the 285 will be a pinched mount on that 9" wide wheel which will cause a rolling of the sidewalls under hard cornering.
The 255/275 combo will be a good fit IMO.
Old May 20, 2015 | 10:21 PM
  #38
AroundTheG37's Avatar
AroundTheG37
What? Am I reading that right? $1100 for the springs and installation?
Old May 21, 2015 | 01:34 AM
  #39
G37xsfun's Avatar
G37xsfun
Swifts springs $300
Spc front 72130 and rear 72260 camber kits $475
Installation of both and alignment $350
$1125 for me
Old May 21, 2015 | 02:34 AM
  #40
G37Sam's Avatar
G37Sam
Eliminating wheel gap without lowering or looking stupid, now that's a million dollar question right there.
You don't want to lower the body, you don't want to raise your tires, you're really left with one thing:
Go to a body shop and extend the fenders downwards lol
Old May 24, 2015 | 06:42 PM
  #41
D1ck-Infiniti's Avatar
D1ck-Infiniti
My G on M wheels and tires. Tires size 245/50r18. Been running them for 6 months with no ill effects. Traction control, ABS got me through a New England winter. The speedo reads about 58 when I am doing 60. All stock. Initially purchased this combo to get the wheels and sell the tires. Since it looks good and works well decided to keep it for a while:
Attached Thumbnails Eliminating Wheel Gap without looking stupid or lowering.-p1030143.jpg   Eliminating Wheel Gap without looking stupid or lowering.-p1030144.jpg   Eliminating Wheel Gap without looking stupid or lowering.-p1030146-2-.jpg   Eliminating Wheel Gap without looking stupid or lowering.-p1030147.jpg   Eliminating Wheel Gap without looking stupid or lowering.-p1030148.jpg
helloandchau
Oct 6, 2015 05:26 PM
Simran Mann
Sep 11, 2015 04:42 PM
Sylo
Sep 3, 2015 04:44 PM
