Excessive rear tire wear
At 30K mi I replaced the OEM tires on my 2010 G37S vert with Pilot Super Sports. Now 15K mi later the rears are wearing twice as fast as fronts. No I don't sideshow! I am 72! The wear is pretty even and same on both sides so rear alignment while the usual suspect may not be the cause. Has anyone had similar experience? The Bridgestone OEMs were terrible but did not show this phenomenon.
tire wear
just about 1/4" above wear bars on rear tires. Pressure ok. both rears similar. Note tire rack website reduces tread life guaranty mileage by half on rear tires for staggered setups(front tires different size)! I know not why,
That's not abnormal with a soft compound performace summer tire. Using two sets of rears for each set of fronts is my experience. If you've gotten 15K and still have usable tread left you've gotten out of them what you should have. If longer mileage is a concern, give up done grip and handling and opt for a longer wearing all season tire like the A/S 3.
If you have staggered figment and can't rotate the rear tires wear out much faster due to extra wheel spin because they're the driven wheels and more scrub wear because they don't turn like the fronts that are usually parallel to your axis of motion.
gsqrd (01-17-2015)
I hear the pilot ss is an awesome performance tire, but your experience sounds about right for that tire. Rear wheel drive+heavy *** end+not being able to swap them to the front+super soft compound=not much tire life. I almost pulled the trigger on these for my vert but went with Bridgestone re760s. My wife drive daily drives the G and I only get to play in it a little bit. It seems the the SS is best for harder driving and some track days, the re760 is better for some fun on the weekends and maybe a track day.
Check out this Car and Driver review. They use the SS as there benchmark tire.
Tire Test: Nine Affordable Summer Tires Take On the Michelin PS2 - Comparison Tests
I'd try to get replacment/pro rated replacement if you can. Either way, drive them hard and enjoy them then maybe look into something diff next time round.
Good luck
Good luck
Sorry about tread guess
I confess, I just guessed at tread depth. It is very close to wear bars compared to fronts. Will probably replace rears with same as hard to find this size. Would have gotten A/S versions initially but not avail... no conspiracy here.
Really? I'm running Bridegstone Pole Position S-04's and they grip like crazy. They actually have a lower tread wear rating than the pilot super sports.
Remember that comparing treadwear values between brands is almost useless. It only has value when comparing tires within the same brand.
I use the standard Potenzas and I keep getting abnormal rear wear. I have the ipl vert and have not changes the suspension but my rear tires typically have more wear on the inside part of the rear tires. You guys see that uneven wear as much as fast wear? I have just 27k miles on them and they say need replace due to the insides over worn. And btw I'm not a fat a** weighing the car down either. Lol. Normal size guy and typically only me doing daily drive down I85 in atl.
