Going back to 19's
Old Jan 19, 2015 | 12:19 AM
nishfish871's Avatar
nishfish871
WedsSport SA67R
Old Jan 19, 2015 | 10:51 AM
ANMVQ's Avatar
ANMVQ
I think a found the wheels-Niche Verona 19*8.5- 19*9.5 245/40/19 and 275/35/19 (+35) for under 1700$ shipped But what the heck are Accerla tires , lol
Old Jan 19, 2015 | 10:58 AM
Originally Posted by ANMVQ
I think a found the wheels but what the heck are Accerla tires , lol
They've been around a while and get middling reviews, on par w/ Falkens, Federals, and other second tier tires. Better than Nankangs, Nexens, and some of the other "real" cheap tires.
Old Jan 19, 2015 | 11:04 AM
Try Treadepot and ask for Andrew, mention myg37 fo nice pkg deals
TreadDepot.com: Niche Custom Verona Matte Gunmetal Wheels
And these summer tires would be 10x better than the Accelera
TreadDepot.com: Toyo Proxes T1 Sport Tires
Old Jan 20, 2015 | 09:33 AM
ANMVQ's Avatar
ANMVQ
Hey blnewt thanx, I'll check them out today. Currently working on a package with Either Hancooks or Falkens for just under $1800 shipped. We'll see. Thank you
Old Jan 20, 2015 | 09:47 AM
ANMVQ's Avatar
ANMVQ
Will call again at 10am when he gets in. Those prices are nuts. ! Thank you
Old Jan 20, 2015 | 06:56 PM
ANMVQ's Avatar
ANMVQ
Wheels I'm going with,. With either Falkens or Copper AS3's square set up.
Old Jan 20, 2015 | 07:23 PM
Very attractive design! Not dissimilar to the Vossen CV7, with the flat hub and clean 7-spokes that butt up square to the outer lip.
Although the location and orientation of the valve stem is a little freaky.
Old Jan 21, 2015 | 09:00 AM
ANMVQ's Avatar
ANMVQ
Thanx John, a little odd I thought also :/ Will 19*8.5 +35 be flush? or should I go 9.5 all around. One thing I stink at is offsets
Old Jan 21, 2015 | 09:06 AM
Do you have a BBK on that car? If you do, or are planning on it, I'd be concerned about those valve stems in a 19" configuration. 20" would likely clear no problem.
There was a brief moment last year where I would have answered that question with confidence. However, if you don't use it you lose it. Hang on...
My front Vossens are 19x8.5" +32, and I've added 3mm spacers to the mix (just in the front). Dropped on RWD Swift springs, that configuration is absolutely perfect for the front. So yes, +35 should be right with a drop on Swifts.
IDK what to say about the rears in that size.
Old Jan 21, 2015 | 09:25 AM
ANMVQ's Avatar
ANMVQ
What you don't know the rears but know the fronts ,LOL
Thank you John,
Old Jan 21, 2015 | 06:43 PM
STownSaint's Avatar
STownSaint
The spacer would make the wheels +32 - 3mm = +29, no?
So +35 would be tucked in by 6mm, relative to your setup?
Perhaps I have that wrong, also might not make much of a difference, far from an expert.
Old Jan 21, 2015 | 07:11 PM
Must. Ask. Brad.
Old Jan 21, 2015 | 07:42 PM
  #29
Must. Ask. Brad.
Lol, Ok
The 8.5 +35 will be just a bit inside the fender on a 245/40/19 but this is a good thing IMO since the front fender edge isn't flat-rolled like the rear fender is. Under heavy compression you may hit the inner fender edge if you go much more flush.
The 9.5 +35 on a 275/35/19 will be just about I think you'll be very happy w/ that combo!
You might want to confirm w/ the vendor regarding Johns concern of the valve stem and the BBK, should be fine but always best to ask first.
Old Jan 21, 2015 | 09:51 PM
  #30
ANMVQ's Avatar
ANMVQ
Hey Brad thanx I went 19*8.5 +35 all around with 245/40/19's. Remember I have a AWD and went square this time . And thanx for the referral ! Andrew is were I got them from
