G37S Coupe - Michelin PSS Advice
Old Dec 29, 2014 | 10:33 PM
baysurfer's Avatar
baysurfer
I'm looking to replace my stock Potenza RE050's with Michelin Pilot Super Sports. I've been running the Potenzas since I bought my G37S coupe - they're the only tires I've ever had on my car and they have a little over 28K miles on them. The rears have about 1/32 tread on them, so it's time to get them replaced...I've been running on them as long as I could, even though they're crappy tires
Here's what I'd like to know:
1. If I get 275/40/19's in the rear, am I going to run into any issues? Am I going to need spacers? Do I need to adjust the camber? I'm running an all-stock setup.
2. Is it better to get 275/35/19's in the rear over 275/40/19's? Any noticeable difference between the two? I'm looking to buy the tires from Costco and they only carry the 275/40/19's.
I'm going to be getting 225/45/19's for the front, so I should be good there.
Any advice/recommendations would be appreciated
Old Dec 30, 2014 | 09:19 AM
chilibowl's Avatar
chilibowl
You cant run 275/40. It will throw off your speedo and VDC.
You need to run a 275/35.
For the fronts, cough up the extra dough and go 245/40 and the car will turn even better.
No, you will not need spacers. No you will not need to adjust camber. Just get a standard all wheel alignment and you will be fine.
Old Dec 30, 2014 | 12:15 PM
Awesome reply
/thread
*Although how on earth did you get 28k miles out of the OEM R050 summer tires? They're OK tires for what they are, but for the price there's much better choices. You're going to love your "new" car.
Old Dec 31, 2014 | 04:47 AM
baysurfer's Avatar
baysurfer
Thanks for the reply. Wouldn't a 245/40 setup in the front also throw off the speedo and VDC?
Awesome reply
/thread
I drove very carefully with them No aggressive handling...mostly highway driving. The Michelins will be the first set of replacement tires for my G since I bought the car new and have never had anything other than the Potenzas. I'm looking forward to getting rid of them
Old Dec 31, 2014 | 05:31 AM
baysurfer's Avatar
baysurfer
So running Michelin PSS tires 245/40/19 in the front and 275/35/19 in the rear using the stock Enkei wheels shouldn't cause any issues? I wouldn't need any spacers or additional adjustments with that setup?
Old Dec 31, 2014 | 01:11 PM
chilibowl's Avatar
chilibowl
100% correct.
Old Dec 31, 2014 | 11:47 PM
John B's Avatar
John B
I love my PSS, but if you don't drive aggressive then why don't you buy a sporty all season if you're never gonna see the benefit of the PSS?
Old Jan 3, 2015 | 03:25 AM
baysurfer's Avatar
baysurfer
The only other tires I'd consider are the Michelin A/S 3's but they're more expensive than the PSS's. Plus there's no need for all seasons where I live (LA).
Old Jan 6, 2015 | 04:03 AM
baysurfer's Avatar
baysurfer
So I called my local Costco to put in an order for the PSS 245/40/19 fronts and 275/35/19 rears. The tire tech told me that running this kind of setup would definitely cause rubbing against the fenders and would sharply cut my front turning radius, making it quite difficult to make turns (compared to the stock 225/45's).
Are any of his statements true?
Old Jan 6, 2015 | 08:33 AM
You'll be fine, tire tech has good intentions, but he's wrong.
Old Jan 6, 2015 | 08:37 AM
drkay's Avatar
drkay
Can 275s fit on a 8.5 inch wide rim? That seems like it's pushing it.
Old Jan 6, 2015 | 08:41 AM
drkay's Avatar
drkay
According to the specifications on Tire Rack the tire is designed to fit on a 9 inch to 11 inch rim. And 9.5 inch wide rim is ideal.
Old Jan 6, 2015 | 09:24 AM
Bonemaro's Avatar
Bonemaro
(I didn't see this answered)
No, because a 245/40 and a 225/45 have nearly the same overall diameter.
Old Jan 6, 2015 | 09:27 AM
Bonemaro's Avatar
Bonemaro
I've run a 275/40 17 on an 8.5" on the Camaro and it was fine. Aren't the rears on these cars 9" wide though?
Old Jan 6, 2015 | 04:26 PM
baysurfer's Avatar
baysurfer
Yes, the rears are 19" x 9" and Michelin recommends a rim width of 9" - 11", so it shouldn't be a problem.
