Wheel Spacers issue
Old Dec 25, 2014 | 10:40 AM
djkrazy's Avatar
djkrazy
Wheel Spacers issue
I got a Infiniti G37s 2010 and I had to get spacers for my winter tires because in the front the \after market wheel would rub on the brake of the car. I got H&R hubcentric 20 mm spacers all around and now i found out I have a gap issue with the spacers on ..... HELP
Old Dec 25, 2014 | 10:03 PM
Not clear on what you mean by a gap issue? Are the spacers not mating up properly to studs and leaving a gap? Or are the spacers too wide creating interference at the fender edge under compression?
Old Dec 25, 2014 | 10:30 PM
djkrazy's Avatar
djkrazy
the studs from the original are sticking out that they are are rubbing the wheel
Old Dec 26, 2014 | 01:31 AM
Gio37's Avatar
Gio37
Is this what your spacer & stud look like and the oem studs hitting the backside of the rim ?
Old Dec 26, 2014 | 08:22 AM
Most wheels have recesses in the back of the wheel mount where the spacers' studs will go. If yours only has a flat mounting flange you're not going to be able to run them
Thanks for the pic Gio!
Old Dec 26, 2014 | 09:30 AM
djkrazy's Avatar
djkrazy
Yeah that is the issue ... Not that bad as the picture but ... Yeah
Intake
Dec 25, 2015 09:38 PM
news1213
Dec 16, 2015 11:06 AM
james6980
Oct 9, 2015 01:28 PM
MJ HINX
Aug 23, 2015 10:30 PM
gcruzjr78
Aug 18, 2015 10:15 AM
